Front end rub/grind
Old 11-14-2011, 11:42 AM
vssman's Avatar
Front end rub/grind
Hey guys:
I have a grinding/rattle that I can't figure out where it's coming from. When stopped and applying pressure to the steering wheel (toward the left), I hear a pretty loud rattle. Also, if I turn a hard left at speed, I'll hear a grinding sound from the front right. I've replaced the U-joints and hubs. Brakes look good, no marks and clears everything ok. The dust shields a clear and I can't see any marks on any rotating parts in the front. Doesn't matter if the front end is locked or not (4X4). Motor mounts look good and I don't see anything touching the frame, etc... Are there any bearings on the right side of the axle other than the hub? I think I have 2 different problems with the first being the PS pump and the second being a rub or bearing somewhere. Any help would be appreciated.
Truck: 96 4X4 2500
Old 11-14-2011, 07:36 PM
DC199512V87's Avatar
i Have a similar sound but thats cause i know the front wheel brgs are toast and the brakes ate worn. Makes for a noisy front end.
Old 11-14-2011, 07:41 PM
98fargo's Avatar
This might sound silly but check that the exhaust isn't hitting anything, especially around the transfer case.
Old 11-15-2011, 06:08 AM
vssman's Avatar
Exhaust is clear, motor/tranny mounts look good - nothing appears to be hitting. The sound is very pronounced after going over a speed bump when the front end compresses and rebounds. Brake calipers are sliding freely, no marks on the inside of the rims or the axle shaft at the tube or knuckle. I'm stumped...
Old 11-15-2011, 08:19 AM
plow's Avatar
From your last post it sounds like a shock or spring.
Old 11-15-2011, 10:41 AM
X2. From that i would check for loose/broken coils and shocks, coil mounts n bolts, etc. Check all things suspension
Old 11-15-2011, 10:50 AM
98fargo's Avatar
I agree with something spring related, check the rubber insulators on top of the springs, maybe ones wore through?
Bmyers2500
09-30-2007 03:41 AM
BlueDually
05-09-2006 06:40 PM
kdgto
07-01-2005 03:18 PM
Gordonville
04-18-2005 09:45 AM
Quick Reply: Front end rub/grind
