FP readings...
FP readings...
i got my fp gauge install this weekend and was wondering if my readings are right. at idle i get 14-15 but really goin hard with the race and bddl turned up i can lug it to 10-11psi....is this normal?
Are you taking the reading before the filter or after the filter before the CP3? A stock intank LP is normaly 9.5 to 10 Psi at idle and can get down to 5 Psi under load taking the reading after the filter and before the CP3. It looks like you are taking your readings before the filter. Normal I would say.
Never mind, I see you have a FASS. You should be good to go... I would love to have 10 Psi under load. Looks fine but some of these guys with FASS pumps should chime in.
Sounds low to me. I have always heard you don't want it to drop below 20 or you're starving the cp3. I have mine set at 32 at idle but since my guage is mounted on the stock filter housing, I don't know what it goes down to under WOT. I do have a rail gauge in cab though, so I at least know it's keeping enough pressure to fee the cp3.
I have a billet fuel filter cap from geno's, that's where I take my readings. I see 25-27 at idle/no load and 20-22 at WOT. I want to get a T put in pre CP3 and a rail guage, but time and money are things that I do not have...
Is your gauge there, or just a fitting that runs line to a guage? If it's cap mounted like mine, how would you know what it is at WOT?
I have my fp gauge plumbed to a Geno's lid as well. It has an 1/8 NPT port in the top of it. You just run line from there to an isolator or to your electric sender and into the cab into your gauge.
The dropping below 20 is meant for rail pressure. You don't want your rail pressure to drop below 20k PSI or you start losing HP. As far as supply pressure to the CP3 you don't want any less than 10-12 PSI in my opinion under WOT. I have 18 at idle and it will drop to 15 WOT but my rail pressure never drops below 25K. That is with the EZ on level 1 and the Hot Juice on level 6.
