Exhuast Brake Switches
DTR's Cow Boss
So I really want too finish up my jake brake install and get a permanent switch mounted but dang I don't want too pay 90 bucks for a shifter mounted switch. So reviewing my options I was going to use a two speed axle switch but I think I stumbled across a really neat idea. Would a floor mounted dimmer switch work? I see three connections on the switch I am for sure its power in power out and a ground and I think my jake brake will match up too this.
Years ago I installed a floor mounted dimmer switch to turn on/off my driving lights. I just mounted it up higher on the firewall to avoid confusing it with the headlight dimmer switch. You shouldn't have a problem doing this. I am not sure but you only need two of the posts as you will be doing an on/off cycle rather than toggling between two on cycles (hi/low).
I believe just screwing it to the firewall (or wherever you mount it) will provide the ground.
Before buying my shifter mounted switch, I built one that I ran for a while until the switch went bad. They are simple to make. I just got a piece of metal, bent it to desired shape & mounted my switch in it. Then I used a old set of handle bar brackets from a bicycle to attach it to the shifter. It actually looked good too. You can get the push/pull switches cheap. That dimmer switch will work though.
DTR's Cow Boss
I think the floor mount will be great it would be about as handy as a shifter switch I am going too napa this morning too get one and wire it up and will post photos of the switch and the new wheels
DTR's Cow Boss
DONE!
This thing is sweet after I found the two poles that I needed plug them wires from the jacobs harness on an crimped them down a little firmer and then wrapped the whole thing in electrical tape and mounted it too the floor. I mounted it a touch high so its a toe operation I might move it a little bit lower than were its at but we will see. This switch only cost like 6 bucks after my discount at napa so I saved almost 80 bucks or more going this way than the flippen 90 dollar shifter switch. I still have a little carpet too trim but my box knife was dull and did not want too saw the carpet. Here is a photo of the install and a couple of the new wheels after the factory alum alloy cracked.
genos switch is only $50... been using it for a year or two now...
http://www.genosgarage.com/prodinfo.asp?number=EKNOB
06-23-2003 08:05 AM
