Exhaust Temp
Old 04-16-2004, 06:06 AM
Brad Gray's Avatar
Exhaust Temp
Finished the guage install last night. I put the pyro in pre turbo and was wondering what temp I should be running at cruise say 80 mph at 2200 rpm. It shows 250-300 at idol and somewhere between 750-800 cruising and will jump when I have the edge comp on 5x5 and get on it , but has never past 1200. Thanks for all the help.
Old 04-16-2004, 06:37 AM
kandgo's Avatar
Sounds like you have it in correctly. It will vary on terrain,load,truck but yours is showing normal. Goodluck,,Rick
Old 04-16-2004, 12:14 PM
phox_mulder's Avatar
I just got mine in as well.
@300 idle.
@800 cruising on freeway.
Had it up to 1200 flooring it yesterday.
Was surprised how much it moved around during an average drive.
All of this on a stock truck.
Well, no fueling mods yet anyway.
phox
Old 04-16-2004, 12:18 PM
apache's Avatar
Same here, I fianlly broke down a installed one. It will stay around 700 at 70mph, 8 psi boost, and havent past 1000 yet. That baby will go up and down per the throttle something fierce. Kindas cool to watch
Old 04-16-2004, 10:14 PM
WHIFF's Avatar
I cruise between 400-600, 250-300 idle (depending on whether it's still cooling down from smoking a ricer...) and tops out at about 1250 WOT. That's what you should be looking for. up hills you might see a 2-300 degree increase. If you have a boost gauge, you'll see that go up, too. If it doesn't, there's something wrong.
Other than that, sounds about right.
Old 04-18-2004, 08:45 PM
silverram323's Avatar
225-300 Idle
525-650 crusing 65-75 mph
1550 at WOT
I need help with WOT #s can any one help?
kev
Old 04-18-2004, 08:52 PM
Originally posted by silverram323
1550 at WOT
kev
You need more air.
Scotty II intake (with the cowl hole) or bigger turbo.
Or less fuel.
Smaller injectors would help that.
Perhaps a small wedge of wood under the go fast pedal to keep it from going to WOT so much.
phox
dodgediesel4x4's Avatar
You should consider a scotty 2. If you don't mind the noise, STRAIGHT pipe it!! A bigger turbo can also solve your problems. I'd try the scotty 2 first and go from there.
Old 04-18-2004, 08:53 PM
HAHA, phox barely beat me to it!!! I guess smart minds think alike.
Old 04-18-2004, 08:59 PM
That would take all the fun out of it.
The truck has 4'' down pipe to tip no muff
I didnt want to spend $200 on a air filter so i got a BHAF instead.
I tryed a hx35 modded turbo and still hit 1550 degrees
How long can i hold 1550 safely?
Old 04-18-2004, 09:01 PM
You could try setting the Turbo master a little higher.
Try 36# and see if it helps.
If you're still running the modded hx35, it could probably handle it?
I'd say no longer than 30 seconds.
About the length of a drag run or sled pull.
With a looooong cool down.
phox
Old 04-18-2004, 09:04 PM
I have the stocker in the truck now. the higher i set the turbo master the higher the EGT I have the turbo master set at 24-30 right now to keep the EGT down
Old 04-19-2004, 02:18 PM
Eat Beef's Avatar
Location: Alberta Foothills - Power to grow with 6 in a row - XLR8
You NEED a Scotty ll ! It will supply your charger with cold air. BHAF uses hot engine compartment air. Also, a larger compressor wheel would help.
Old 04-19-2004, 10:50 PM
Mslaughter's Avatar
What is a scotty 2? Sorry I'm just learning about diesel motors. I take it a bhaf is a big air filter?
Old 04-20-2004, 01:50 AM
Here is a scotty 2.
http://www.wildcatdiesel.com/scotty2.htm
A bhaf is a Big Honkin Air filter. Here are some more terms to cram into your mind.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Quick Reply: Exhaust Temp
