Engine miss at RPM
Old Apr 8, 2012 | 12:07 PM
Dieselbuilder's Avatar
Engine miss at 2200 RPM
I have a 2001.5 24v engine standard it has a miss at around 2200- 2300 if you hold it steady. I have a new injection pump and the fuel pressure is at 13lbs, and no codes. The only thing I can see is mechanical ( injectors ) going to change them out next week to see, they have been in for the last 9 years... so.. I have a new set of 120hp going in ( new body and tips ) any one run into this situation before? any ideas would help..
Last edited by Dieselbuilder; Apr 8, 2012 at 12:09 PM. Reason: rpm numbers did not show
Old Apr 8, 2012 | 04:23 PM
Jim n Sue's Avatar
Is this the RPM that you normally drive, I have the same problem at about 60MPH and its been suggested to me that its the Throttle Position Sensor, I did have a big throttle issue 2 years ago and had to replace the TPS which solved that problem but I think I may need another one
Old Apr 8, 2012 | 08:32 PM
This is where I can realy see it but when driving you notice it most of the time, and yes I have a new timbo tps this is a nother thing i will reset when I install my injectors as well as a valve set
jefjsak
Jan 15, 2015 03:44 PM
Dieselbuilder
24
Jun 17, 2012 12:25 PM
Buffalo
Dec 2, 2007 08:35 PM
fishin fever
Feb 22, 2004 08:32 PM
94dsl4x4
Mar 21, 2003 02:58 PM
