What EGT at shut-down?????
Old 06-12-2008, 03:56 AM
rbertalotto's Avatar
What EGT temperatures should I be looking for at shut down. I can program my Attitude to either shut down after a predetermined time or at a particular temperature. Currently I have it at 450 degrees.
Advice?
Old 06-12-2008, 04:16 AM
Topper's Avatar
I shut mine down when it drops below 300.
Topper
Old 06-12-2008, 05:14 AM
elirandolph's Avatar
350 with pre-turbo probe
Old 06-12-2008, 05:39 AM
jurish's Avatar
Advice?
My attitude is set at 300.. pre turbo probe (the only "right way")
Old 06-12-2008, 05:50 AM
bnold's Avatar
300-325*....
Old 06-12-2008, 06:55 AM
MikeyB's Avatar
300 here, unless I'm in a hurry then it's 350.
MikeyB
Old 06-12-2008, 07:22 AM
JP-4.5's Avatar
MikeyB
Just like he said... You can actually raise the throttle slightly to move some air thru the system and it cools down a little quicker than just leaving it idling.
If I am in a rush I will hold RPM at 1000-1100 for several seconds until I see the temp start to drop and then let off and the temp usually drops quick after that.
Old 06-12-2008, 08:52 AM
AkitaSumo's Avatar
Turning off the AC helps too. My Attitude shuts her down at 300*, post Turbo temperature.
Old 06-12-2008, 09:02 AM
JP-4.5's Avatar
10-4 on shutting the AC off. I forgot about that. I try to turn the AC off a little prior to getting to my destinations. The air usually stays cool for a short amount of time after shutting it off.
Old 06-12-2008, 09:07 AM
AH64ID's Avatar
250*-300* works for me, and the way I drive with this $4.79 fuel its usually at 225* so no waiting needed.
Bumping the rpms for a few seconds really helps... more air and more oil
Old 06-12-2008, 10:19 AM
ptgarcia's Avatar
I usually just turn it off, and temps are around 400* pre-turbo. If I've been towing I let it cool a minute or two at an idle in neutral.
Old 06-12-2008, 11:53 AM
molalla1ton's Avatar
timer shuts it off at 300* for me.
Old 06-12-2008, 12:01 PM
snoyes's Avatar
I'll normally shut-down at about 300.
Old 06-12-2008, 01:19 PM
DTR 1st Sergeant
soulezoo's Avatar
We have to worry about that???
Old 06-12-2008, 01:49 PM
AkitaSumo's Avatar
ummm cool her down...or burn more of that precious gold...
Quick Reply: What EGT at shut-down?????
