EGT Gauge Issue
Old 08-01-2009, 11:44 AM
pcgym's Avatar
EGT Gauge Issue
I installed a Pricol gauge set in my truck earlier this year and recently my EGT gauge will randomly quit working while driving down the road. I can thump the face of it and it will act right for a while before repeating. These are the first I have ever installed before... I have always put Isspro's in trucks in the past. I followed the directions to the letter... has anyone had issues with these before? Is there something I may be able to try before buying a new gauge/ kit? As usual I am grateful for any assistance... this site has always been a big help to me-
Old 08-01-2009, 02:03 PM
1985cucv's Avatar
loose connections is what i would check mine did the same thing also i noticed when i installed my gauge the 2 leads that connect to the probe were touching and shorting each other out i separated them with some e tape and all was better.
Old 08-01-2009, 08:29 PM
pcgym's Avatar
Good point... I will check it out. I appreciate it-
Old 08-01-2009, 10:52 PM
Jordan5687's Avatar
That's what I'd check first too. After that, might be more internally with the gauge itself, if you tap on it and it works a bit, look at getting it replaced...or try breakin it down yourself, but I'd just swap it out.
Old 08-02-2009, 12:38 AM
rip 112's Avatar
Make sure your ground is good...
dan123dbl
02-13-2015 05:47 PM
chris25151
15
05-24-2009 09:53 AM
jmccart
03-18-2007 10:03 PM
DDysput
05-05-2004 07:44 AM
Quick Reply: EGT Gauge Issue
