edge-low boost fueling question???
Old 04-02-2007, 05:15 PM
rjm022's Avatar
when i change it off of the default #1 setting and go back to check it to make sure it is at the new setting- it is back at the #1 setting!! i called edge today- they said it changes to my new setting-but when i go back to check it again, the unit assumes i am going to change it again and defaults back to default setting #1!! i never read any posts,etc on this site about this. can anybody confirm this? thanks.
Old 04-02-2007, 10:11 PM
jgiachino's Avatar
I'd call back and talk to another tech support person....that doesnt make a lot of sense...hopefully someone will chime in
Old 04-03-2007, 07:02 AM
omaharam's Avatar
I believe that is correct. You should be able to tell by the amount of smoke and how fast it spools.
Old 04-03-2007, 08:25 AM
CamperAndy's Avatar
Mine retains the last setting. If I set the level 2 (Tow) to low boost of 3 that is where it is when I go back into it.
Exhaust opacity (smoke) is a tough thing to tell between each individual level.
Old 04-03-2007, 04:53 PM
rjm022's Avatar
interesting-anybody else???
Old 04-03-2007, 06:42 PM
bluebull's Avatar
Although I don't have any experience with the Attitude it just doesn't make any sence for it to show the previous setting and not the present setting. How many electronic gizmos do you know that will show you the previous setting and not the present one. Total horse pucky. Call and talk to someone else or better yet e-mail them from their website. It might take a couple of days for them to respond but I'll bet you'll get a different answer.
My thoughts it's defective. I would be sending it back for an updated on or a refund. Their choice.
Old 04-03-2007, 09:01 PM
omaharam's Avatar
Mine does that, and I know it is functioning correctly. I can tell a difference if I change the setting. But no matter what I set it to, when I go back in it is on the first setting.
Old 04-03-2007, 09:03 PM
rjm022's Avatar
seems to be a 50-50 split on this subject. i'll give edge a call tomorrow.
Old 04-03-2007, 09:38 PM
PEAKSTRYDE's Avatar
As Camper Andy said
It should keep the settings that YOU put in it!!!!!!!!!!!!!!!!!!!!!!!!!
Must be an issue with your box.
Old 04-03-2007, 09:39 PM
reidsram's Avatar
mine does it to so i took it back where i got it and they replaced it with a new one. the new one does it to so i dont worry about it
Old 04-03-2007, 10:46 PM
swansong04's Avatar
mine does it too ... phoned edge about it last yr .. they said that is the way it is .. kinda sucks .. oh well .. THE J/A still rocks !!!!
Gary
Old 04-03-2007, 11:06 PM
973604x4's Avatar
mine didn't do it? weird.
Old 04-03-2007, 11:57 PM
bigredBCS's Avatar
make sure you hit enter!!!! i forgot to hit enter when setiing my egt defuel when on the dyno.....let just say id put out more hp if i wasnt defueling at 1250!lol
Old 04-04-2007, 06:34 PM
rjm022's Avatar
finally- edge explained why some onwers have it stay when they switch the setting, while others-it defaults back to setting #1. here is their response!
We have different versions out there. So some of the
older versions will retain the info because it is an older version
attitude. The newer ones will do as I said before. So if you want to
send yours in, I can test it for you, but that is just the way the newer
attitude works. Let me know.
Quick Reply: edge-low boost fueling question???
