Edge Juice w/ Attitude ?'s
On an 03 what would be the best stck for a edge juice w/ attitude? Smarty? mp3? what kind of results such as rpm, boost (obviously depending on turbo), HP, you end up with? Thanks!
I was looking into the same thing, some say the TS MP-8 works well. But I dont know if that goes for the 03 too. I will probably go with the Xzillaraider II and download the stacking software, they have a couple different ones you can do over the computer with a usb cable.
Not sure of the real answer here. But I don't think on an 03 you want to stack the Edge J/A with the MP-8. In the 03 model the Edge is adding pressure, as is the MP-8. That could make bad things happen man, bad things...
I run both on Extreme. Level three Predator, Hot #5 on Juice. Never saw more than 24,000 at WOT on my rail pressure guage. Of course I usually just use these two while pulling or racing.
I have the updated tune for the predator saved but have nevr loaded it.
I'm not sure what "level 3" means on the Diablosport Predator but maybe there's a different one out there. Anyway, some of the puff tunes and RKL tunes are without timing and will stack with another timing box like the Juice while not increasing pressure. I have run that stack by looking at my sig and while it made good power it made very hot power. I need to get a Smarty to try next and then if that doesn't do what I want I'll just give up. The best advice would be to go to the Diablosport web site and register and then read some of the threads. Johan and Mike are moderators there and they can lead you in the direction of the tunes you would need.
