Dumb question...
Old 11-05-2006, 09:27 PM
Mopar440_6's Avatar
Dumb question...
Ok, I searched and can't find an explanation I can understand. What exactly is this "killer dowel pin" everybody keeps talking about fixing? What does it do and what has to be done to fix it? Considering that I haven't had the truck all that long what other preventative maintinence should I do?
Old 11-05-2006, 09:36 PM
wilderness's Avatar
It is an alignment pin on the timing cover that works out in to the pump, cam and vacuum gears and can cause a crack in the cover. Or it can fall in the oil pan and couse no prob, or it can stay in and never cause a prob. Best bet to fix it!
Old 11-05-2006, 09:53 PM
Common's Avatar
Or destroy the engine...
Old 11-05-2006, 09:56 PM
wilderness's Avatar
Yep, I prefer to infasize the FIX IT! Once you find out what it is you loose alot of sleep over it until it's fixed.
Old 11-06-2006, 08:17 AM
displacedtexan's Avatar
Here is a link to the TST kit to fix it. http://www.tstproducts.com/index.asp...PROD&ProdID=64 It is not a tough fix, just 3-4 hours of basic wrenching...
And the seal included is like $35 at cummins, many wonder why a bolt, washer and seal is so expensive. Plus it includes great instructions.
calvin
01-04-2003 10:41 AM
TPilaske
01-01-2003 12:57 PM
Push Rod
12-31-2002 10:46 AM
wheels
12-22-2002 10:49 PM
bigbaddiesel
12-07-2002 07:40 PM
Quick Reply: Dumb question...
