Dual Battery install
Old Dec 10, 2004 | 11:20 AM
Nuttymopar's Avatar
I currently only have 1 Optium Yellow top battery in my truck. Now being winter and plowing, I think that my guage is rather low. It is usually about the 1st mark above the 8 mark (at night). This is due to extra lights, stereo cranked up listening to tunes, stuff like that. When I plow though, it gets down to the 8 or below. Of course it is because of the plow and turning to the right/left/up/down when it hits the stops. So, I was thinking about installing another optium Yellow top mounted sideways with my first one in the stock location. I have measured and it looks like they should be fit, just modify something to make for a hold down piece.
My question is. I know I can just go from Pos to Pos and Neg to Neg. But what should I purchase to allow them to be isolated from each other and yet keep a good charge? I figure I should be able to connect all of my accessories to one and the starter to the other? Any type of special cables I need since one cable will be going between the batteries and how to run a cable to started?
I haven't had any problems starting, just trying to boost my volts out for those cold snowy nights with all accessories turned on.
Thanks.
Old Dec 10, 2004 | 11:24 AM
Chrisreyn's Avatar
Scott, there is an isolator available for this, lets them charge independently. I purchased one several years ago for a Cj with a winch set up, but I had it installed by the shop , and dont realy know the specifics. I purchased it through Warn, tho I am sure there are others out there.
Old Dec 10, 2004 | 12:23 PM
jiMMyCTD's Avatar
i would get a better alt first. i have a mean green 190amp i think alt in my landcruiser and one yellow top.
i have a pretty nice stereo and all kinds of lights under the rig and a winch.
i have ran everything at ngiht all lights on and stereo blasting and winching someone up a hill and my gauge went from 14v to 13 12 lowest under heavy winching.
jiMMy
Old Dec 10, 2004 | 12:48 PM
Nuttymopar's Avatar
Would any one know the Amps of the current 92 stock Cummins alternator? I think it is listed on my windows sticker but need to track that down to verify. I do know it is the heavy duty alt. I think maybe 120? or 140?
Then I can figure out what size isolator I would need.
Old Dec 10, 2004 | 04:04 PM
Stock alt. is 120 amp. There's a real good thread from Jim Lane about swapping in a Leece-Neville alternator to really fix the problem. https://www.dieseltruckresource.com/...threadid=55799
Old Dec 12, 2004 | 01:43 AM
frostie's Avatar
remember, auto applications--120 is peak, truck alternators rated at 140 mean thay can run for long periods at 140. different ratings.
Old Dec 13, 2004 | 06:58 AM
Nuttymopar's Avatar
WOW, what a difference 2 batteries make. I connected my other Yellow Top battery this weekend. Lights are much brighter now. Before I was only getting about 10.3 volts to the rear tail lights and extra lights. I haven't checked yet but they are the brightest I have even seen them . I can be running all lights on the truck now and even having the plow at full lift holding the switch and meter stays above 9 - 10 volts. Before, it would pegged BELOW the 8 mark on the meter. I did need to make a quick bracket to hold them safely in the original battery box.
rabuntjer
Aug 24, 2012 05:36 PM
jesussaves
Nov 7, 2010 06:55 AM
RDR
27
Dec 23, 2008 07:34 PM
DNRCustoms
Nov 11, 2008 08:25 PM
Timberman
Feb 5, 2007 12:13 AM
