How do I get the axles in the front end without damaging the seals?
Old Aug 8, 2009 | 04:45 PM
SSV1761982's Avatar
I have am doing ball joints and a bearing while I am at it. Looking ahead, what is the best way to get the axles back into the the punkin without damaging the old seals? I am sure there is rust and crud in the axle tube. When sliding the axles in, won't they pickup that crap too?
Old Aug 8, 2009 | 07:46 PM
darrenw's Avatar
when i did mine i was really careful and all was well.
Old Aug 9, 2009 | 10:44 AM
ClayBob's Avatar
A number of guys have cleaned their tubes using a vacuum but there are some gotcha's. I think if you do a search on front wheel bearings you'll find some useful tips/warnings about cleaning the tubes.
My tubes were clean, I just carefully slid the axles back in, no problems with my seals. Slow and Go.....
Old Aug 9, 2009 | 09:48 PM
Nick02Ram's Avatar
Maybe I'm reading this wrong, but I never had to pull my axle out of my '02 when I did a hub?
...But anyways, whenever I put axles back in, I push down on em while pushing in, the axle balances on the end of the axle tube and the end never touches the inside.
Old Aug 9, 2009 | 10:01 PM
SSV1761982's Avatar
I am doing the Ball Joints
Thanks for the replies so far. I guess I will just be gentle when putting the axles in.
My new to me ball joint press just came in the mail. I did the upper and lower on the passenger side tonight. The only problem I had was the upper kept wanting to get cocked a little crooked. I finally froze it for an hour and it went in smooth.
It is a good thing I am not in a big hurry, it is a good workout and the temps finally got into the 90's.
Old Aug 10, 2009 | 12:20 AM
nickg's Avatar
I'm sure you did this already but I use fine sandpaper to clean out the balljoint bore and a light skim of grease/never seize and it will slide in easily, that and a large hammer to smack on the spindle/axel assy the vibration will get the BJ moving when the press wont move the BJ any more, same trick works well when doing U-Joints as well
Sep 22, 2019 07:27 PM
realest
Dec 11, 2010 10:38 PM
bigbrowndog
Sep 2, 2007 08:16 PM
PsRumors
18
Oct 19, 2005 05:18 AM
SkyHarborCowboy
15
Sep 9, 2005 11:50 PM
