dana 60 questions
Old May 11, 2009 | 01:53 AM
NO_SPRK's Avatar
dana 60 questions
So I'm buying an 87 drw 4x4 dodge gasser. Its got some old funky selectro hubs on it. So I want to convert my truck to drw so I'm planning on swapping outers on the axles so I can have a srw d60 for my 68 jeepster commando wheeler.
Sooooo can anyone give me some info on these hubs and if I should change them what do I change them to.
THANK YOU
Old May 11, 2009 | 01:31 PM
NotEnufGarage's Avatar
I had those on my '90, but changed over to a '92 front axle with the Warn type internal hubs when I switched to 3.54 gears and 35 spline outers. What you have work in essentially the same way, only the **** is the whole outer housing instead of an internal ****. I think the hubs castings are different, as well.
The 92/93 D60F uses the same hubs, selectors and outers as the 80's Chevys and GMC's use, so lots of parts available.
tankeryanker
Jan 19, 2005 04:18 PM
Mechanos
Jan 22, 2004 12:45 PM
matthopp
Nov 21, 2003 04:49 PM
mcevins
Jul 3, 2003 02:06 AM
Stamey
Apr 18, 2003 10:34 PM
