coil springs
coil springs
Good afternoon gents
Just tried doing a search for the numbers for the front coil springs,in the search category,but could not find.Is the preferred number that we want is 046??
Are you replacing your stock springs? Most diesels came with a 038/039 combo, or a 039/046 combo. If you are planning on putting a winch on, or a heavy bumper, get the 046/047 combo. If you are going to plow with it, get 047/048. That's what I put in my truck, and I love it. It rides a little bit stiffer, but I can handle that. It only drops 3/4" raising a 1,000+ lb. plow!
If you need a part no. go to your dodge dealer and have them look up springs, and the last 3 numbers are the ones listed above. I paid around $300 for the pair, but well worth it! Plus I sold my old springs on ebay for $92
What the the HD springs come out of? I'm guessing a HD 3500 but I never knew they made somany different springs. not saying my stock springs don't work but if I could gte a little bit stiffer ride it would be nice.
DM01
DM01
I haven't ever seen the 047 and 048 springs on a stock truck, but they could be for a 3500 w/ plow prep, just a guess. All I know is that I get no sway when cornering with the stiff springs on there! Plus they gave me an inch of lift
I installed sky-jacker 2 -1/2" springs in the front of mine. Heavy bumper and plow. 1-1/2" drop with the snow- plow raised. I used good quality stock length shocks. I consider this a essential upgrade. The truck sits level. Tows well. Decent stiffness. (stiffenenss is REALLY controlled with adjustable gas shocks. BUT:$$$) I believe that there was a price tag of $92.00 each. They were sold as replacement parts to a lift kit. Just what I did. And the most satisfying upgrade.(well....except for power enhancements) Simple do it yourself project. I have noticed some RAMS sit higher than others. Mine was ordered as heavy as I could . Sno-prep and all. Sat 2"lower than my brothers 3500 with 235's with out any x-tra pkgs.
My truck came with 265's and now sports 315's..and I'm 2" taller than his 3500!
signature600
03-29-2009 12:57 PM
