Code: Fuel injector group 2 supply Vo - What do I do?
Old May 21, 2007 | 11:21 AM
strictlydiesel's Avatar
Engine is very erratic and the vehicle cannot be driven. There is no Dodge dealer on the island and my mechanic takes forever to deal with these problems. I've had something like this happen before with the same erratic engine 5 months ago. It took him 2 months to figure out I needed a new camshaft sensor.
Mind you he gave the truck an engine wash yesterday and it started acting up late last night. Just degreaser, hose wash, and engine kote treatment. Air filter was covered.
Any ideas guys?
Old May 21, 2007 | 11:35 AM
Sprinter17's Avatar
Muted User
Dirty engines are happy engines in my book.
Old May 21, 2007 | 04:34 PM
White97GTVert's Avatar
Pull your injector connections and get them dried out. Reconnect with the edge hooked up first (after you get both sides good and dry) and then fire it up and see if she'll run.
If not disconnect the Juice and see if that is the problem. I get that code sometimes with my Juice just outta the blue. Its annoying when it happens. Don't see it took much these days with the Smary on board but before that I would get it any time you jumped on the freeway and the truck was cold.
Old May 23, 2007 | 09:24 AM
Thank you very much kind sir!
OK after I got them all cleaned and dried out same thing with Edge in loop. Once I connected it stock injectors - left edge map sensor and others still connected - everything is fine.... Why? What is wrong with the Edge?
Is group 2 injector the middle connector on the engine? It says open circuit there when the edge is hooked up and I'm not sure how to trouble shoot the edge from there.
Old May 23, 2007 | 03:13 PM
Not really sure what is wrong with your Edge..
I have had the "Fuel injector group 2 supply..." code come up multiple times. Other people have reported the same thing.
It seems like it comes up more when people are jumping on the truck before it has warmed up and over the 170* mark.
There may be something physically wrong with your Juice. I would call Edge support and talk to them. They may be able to help you out or get you the info you need to send it in for service.
When you cleaned and dried all the connections did you also clean and dry the Edge connections as well? I am assuming you most likely did.
My vote for now however is that something went wrong with your Juice. Sorry!
j-dubya
Sep 28, 2005 08:39 AM
peteygirl
0
Mar 14, 2004 09:10 PM
4x4
Feb 25, 2004 05:14 PM
rattle_rattle
Nov 30, 2002 08:28 PM
