clearance lights
Old 10-20-2006, 12:25 PM
moonshinedoc's Avatar
clearance lights
My truck did not come with clearance lights and was thinking about putting some on. I have a white, bright white according to mfr., and have been looking at those reacon lights. does anyone have any sudgestions what would look good, or pics would be better, between the smoke, clear or bright white? Appreciate the help!
Old 10-20-2006, 12:49 PM
Mcmopar's Avatar
Go with the factory ones. They fit great and do not leak.
Old 10-20-2006, 03:54 PM
goose2's Avatar
The factory one also come with a template that makes drilling and the overall install mutch easier.
Old 10-23-2006, 06:38 AM
JMalone's Avatar
I had the dealer put factory ones on after I bought the truck -- the cab lights were actually the deal-breaker when I was buying the truck. I told them they had to put cab lights on it at their cost or no deal... Hey really, really didn't want to, but they did...
Old 10-23-2006, 06:58 AM
Administrator/Jarhead
madhat's Avatar
This is a picture of BigDan's truck at night, he bought some aftermarket head lights also. They are recon's, but I think that he put different bulbs in it. I have some on the way, pic's to follow.
https://www.dieseltruckresource.com/...icture_349.jpg
Old 10-23-2006, 11:42 AM
PEAKSTRYDE's Avatar
I bought the "clearance light kit" from the dealer about a month after I got the rig. Great kit, easy install, factory plug'n play.
I believe that REAL trucks deserve the "yellow lights"!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 10-23-2006, 04:26 PM
Jus Cruisin's Avatar
I agree, if you're gonna add clearance lights they should be yellow and not on a 1/2 ton.
Old 10-23-2006, 07:55 PM
JMalone's Avatar
I third that motion!!!
Old 10-24-2006, 01:36 PM
Lee S's Avatar
"Go with the factory ones. They fit great and do not leak."
Some leak.
One of the standard factory lights on my 2005 leaked and, when I called about a replacement, I was told there was a technical bulletin on the problem and the original lights had been replaced with a new design. I couldn't replace just one light. Since I'm still under warranty, I had them done at the dealer for free. The new lights haven't leaked.
Old 10-27-2006, 08:54 AM
Jonesey's Avatar
Some leak.
The factory ones have and still do leak. When I ordered my truck you had no choice. All 3500s came with the cab marker lights. They leaked from day one. I replaced several of them at my own expense rather than taking my truck in for some damage by an uncaring tech, as always seems to happen to me. I siliconed the crap out of them but eventually they start to leak again. I next tried Recons and they were worse than the OEMs. When the 06 came out they had a new design with a separate base gasket. I ordered a set of them and so far so good. A friend has an 06 which has two with condensation in them. So even the new ones are not exempt from leaking. That is why my signature says " just say no to cab marker lights". It is not worth the risk. I will never own another truck with them, but to each his own.
Old 10-27-2006, 09:37 AM
MedicShawn's Avatar
I had some problems with the factory ones and condensation. I switched to the recon smoked with no problems so far.
FYI the only diffrence in the recons is the bases. The smoked ones are black the other ones are silver.
Old 10-27-2006, 07:46 PM
SlowJeep's Avatar
I've always wondered, what purpose do clearance lights serve?
Old 10-27-2006, 08:02 PM
Festus's Avatar
It makes the DRW trucks DOT legal for one.
Old 10-28-2006, 03:16 PM
scoggins's Avatar
I'm with you fella's
Old 10-29-2006, 05:15 AM
who puts clearance lights on a 1/2 ton? thanks for the input but that pic with those bright lights are nice!
Quick Reply: clearance lights
