Check out the 6" intake!!!
Old 01-30-2008, 09:25 PM
cconrad331's Avatar
Lightbulb Check out the 6" intake!!!
Pictures are a little blurry but what you think?
I'm not done with the polishing and have even thought of painting the intake white to match the truck but I couldn't wait any longer to try it out. The sound of the turbo whistle is unbelievable, without the silencer ring of course. The intake is 6" aluminum to a 5" adapter then into the stock turbo boot. Next step is the filter shroud, all aluminum.
Old 01-30-2008, 09:33 PM
4_play_ram's Avatar
Nice job
very clean install I like it
Old 01-30-2008, 10:01 PM
na4now's Avatar
Thats what I want to do with mine. Is that just a 6" alumunim elbow, with a bung welded in?
What filter?
Old 01-30-2008, 10:58 PM
Sinbadd's Avatar
Looks good, just make sure that aluminum tube has no chance of contacting the positive battery terminal.
Old 01-31-2008, 07:56 AM
cconrad331's Avatar
Na4now
yes it is an aluminum 6" elbow that I rolled down to fit a 5" piece of aluminum into it and then welded it up. Started with a 3/4" piece of plate and did some grinding on it to fit the 6" and then attached the air sensor to that. S&b 6" by 9" filter. Just over 120 for parts and a little time is all it takes.
Old 01-31-2008, 08:59 AM
haloman's Avatar
Very Nice!
Old 01-31-2008, 09:22 AM
rockcrawler304's Avatar
I like it.
+1 on the battery terminal contacting it though. Careful
Old 01-31-2008, 02:22 PM
cconrad331's Avatar
Battery cable not as close as the picture makes it look....unless it wears a place on the cable and I hope the shroud I build helps support the intake a little better. Thanks for the opinions!!!
Old 01-31-2008, 02:30 PM
Justice4all's Avatar
I like it! Nice and simple. Good clean look too.
Old 01-31-2008, 06:26 PM
DodgeCTD's Avatar
This is exactly what my home made intake looks like except mine is a 5 inch. Works great and has alot of whistle
Old 01-31-2008, 06:39 PM
UnrulyNFS's Avatar
That's really kewl! Nice work.
Old 01-31-2008, 06:40 PM
Patriot2500's Avatar
Looks great!
Old 01-31-2008, 08:17 PM
roadhammer's Avatar
Thats sweet looking nice job
Old 02-01-2008, 03:18 AM
jwb600's Avatar
nice work! I built my own also and I like it alot better compared to the fitment of the tube on ones made by big companies. I run a 6" afe (stage 2 filter) and it whistles alot also
Old 02-01-2008, 05:46 AM
homewrecker's Avatar
I was wondering what you where planning on doing with that filter!!
Quick Reply: Check out the 6" intake!!!
