Changing the batteries. What do I need to know?
Old 08-21-2011, 01:20 PM
JDiepstra's Avatar
Just want to avoid any problems. My original batteries are no longer holding a charge after almost 8 hard years.
Change one out then the other or disconnect both then reconnect both?
Leave no batteries in the truck for a while or swap out quickly?
Leave the Smarty programmed in or set back to stock?
What else?
Old 08-21-2011, 01:55 PM
Administrator/Jarhead
madhat's Avatar
It does not matter. One at a time will keep your clock and radio programmed... actually, I don't think it will reset it even if you take them both out at once unless you leave them out for a while.
Don't worry about any of that other stuff.
Just be safe with the cable ends, they are still hot with one battery connected.
Old 08-21-2011, 05:03 PM
06RAM2500's Avatar
One then the other. Clock does reset with both grounds disconnected. If you got a glove, stick it over the positive cable (if doing one at a time) to prevent it from shorting out. As far as the Smarty, no need to worry.
Old 08-22-2011, 06:56 AM
JDiepstra's Avatar
Thanks guys
TayTay
69
05-13-2015 03:42 PM
NCTURBOS
02-19-2007 07:51 AM
PurNLoud
09-08-2006 11:40 PM
JKM
07-03-2005 04:59 PM
Quick Reply: Changing the batteries. What do I need to know?
