Change rear diff fluid
Old 08-16-2003, 07:49 PM
lawnman757's Avatar
How many quarts of fluid does it take to change the rear fluids? I can not seem to find it in the owners manual. I use the truck to pull a landscape trailer short distances and wanted to change to synthetic. Any suggestions?
Old 08-17-2003, 10:06 PM
Groucho's Avatar
Re:Change rear diff fluid
Your truck shouda shipped with synthetic. I estimate it holds about 7 to 8 pts. I filled mine, set each side on an incline for 10 minutes, then checked it again. About 1/4" below the fill hole will get it. No need for additive to antispin gear (if an AA axle - an '03). If you are towing heavy loads, you may want to jump up to 75W140 GL5 synthetic. The manual says 75W90 GL5 synthetic.
banana
12-01-2009 11:44 PM
usedtostrokeit
02-02-2005 03:51 PM
calvin
09-28-2003 11:44 AM
lawnman757
08-29-2003 01:03 AM
Mark Thomas
08-18-2003 12:20 AM
Quick Reply: Change rear diff fluid
