Carrier bearing
Old Oct 22, 2007 | 06:26 PM
swhite832's Avatar
Carrier bearing
After reading various post about carrier bearings, it is my assumption that the carrier bearing should have no play(mine does). Is this a correct statement?
Also, there is some question as to weather this little gem has to be pressed off and on? I have seen it posted both ways. Is it possible to disconnect one side only then slide the thing off and slide the new one on?
This is a 4 wheel drive dually extended cab.
Old Oct 22, 2007 | 09:08 PM
mhuppertz's Avatar
There should be no play, like any bearing, and for how expensive they are it's best to have a drive line shop press it on for you. It's easy to damage the thing trying to pound it into place. Just my $.02..
Old Oct 23, 2007 | 06:43 PM
swhite832's Avatar
Took it apart...bearing is fine..the bushing is torn a little. Can I drive it like that?
Old Oct 23, 2007 | 07:05 PM
mhuppertz's Avatar
By bushing do you mean the rubber shock mount surrounding the bearing? You can drive for quite some time with the rubber shock mount compromized, as long as the drive lines are balanced fairly well and you down dump the clutch too much, but no matter how well the shafts are balanced you most likely will get some vibration from it.
ajb1974
Mar 18, 2015 05:49 PM
Joseph H. Smith
16
Jan 6, 2007 08:13 PM
DodgeGirl
Sep 20, 2003 03:06 AM
Stroke This 24V
Jul 3, 2003 02:40 AM
rich
0
Oct 4, 2002 06:18 PM
