Carrier bearing and lifts?
Old 04-14-2009, 11:33 PM
dieselrob's Avatar
Anyone put a 3 inch add a leaf on there truck? Did you have to shim your carrier bearing down or didnt mess with it? Im in the middle of doin the leafs and was just curious before i forget about it and toast the carrier bearing, because its a pain takin the drive shaft loops and sheild off, so if it needs it all do it now beofr it gives out.
Old 04-15-2009, 01:29 AM
Fishin2Deep4U's Avatar
I had to shim mine down 1/2". This got rid of a small vibration.
Dave
Old 04-15-2009, 07:01 AM
dieselrob's Avatar
How much lift did you put on? I didnt think it would be that much but mabey so.
Old 04-15-2009, 11:09 AM
rollincoal01's Avatar
I had to shim mine down about 1.5". I got the skyjacker 5" lift with full leaf packs though. You should still have to shim it down a little bit with a 3" aal.
Tommy
Old 04-15-2009, 09:21 PM
dieselrob's Avatar
I put a 1/2" shim on it tonight so well see how it feels. I got about 4 inches of lift from it tho. Empty my hitch was 22 inches give or take a little, now its 25.75 with about 1000lbs of junk and parts in the bed. Im hoping its not gonna be over 26 when i empty it and hang 800 to 1k out front.
Old 04-15-2009, 11:30 PM
2" over stock rear height.
Dave
Old 04-16-2009, 08:35 PM
dieselrob's Avatar
Im palnning on gettin it running tomorro night and it has to make a 3 mile drive to the palce where we are gonna be welding everything. So well see if its gonna be ok or not. It looks like its almost at the stock angles compared to the other trucks.
ajb1974
03-18-2015 05:49 PM
Joseph H. Smith
16
01-06-2007 08:13 PM
signature600
02-13-2004 11:22 PM
Stroke This 24V
07-03-2003 02:40 AM
rich
0
10-04-2002 06:18 PM
Quick Reply: Carrier bearing and lifts?
