Cargo light won't come on
Old Aug 18, 2008 | 03:35 AM
Diesel Jeff's Avatar
My cargo light won't come on with the cargo light switch. I am under the impression that the 3rd brake light is also the cargo light? It works with the brakes, and I think reverse lights, but when I hit the cargo light switch, no go. The little led light on the switch itself comes on, but not the cargo light. I checked the fuses, and all is ok. Anybody have any ideas? And how can I remove the cargo light switch housing without breaking it?
Thanks.
Jeff
Old Aug 18, 2008 | 06:25 AM
Philip's Avatar
The 1st gens do not have a third brake light. That almost useless light on the back of the cab is a stand alone light. If the switch light comes on them most likely the bulb is blown in the cab light.
If you pull the light out to check the bulb make sure it seals up good when you reinstall it. If not you will get water into the cab.
stratos201proxl
Jan 16, 2014 11:04 AM
nugirlintexas02
Jul 28, 2007 05:33 PM
brandon's93
May 13, 2006 12:40 PM
banks
May 9, 2005 03:37 PM
darrin
Nov 28, 2003 05:58 PM
