can someone on here help????
Old May 8, 2008 | 11:58 PM
fullthrottle07's Avatar
i am trying to download the revo to my smarty but no luck i also tryed the 7zip but there is a2007 and 2008 then they both have two different ones so which do i go with and were from there? thanks
Old May 9, 2008 | 10:03 AM
mj007's Avatar
Yeah .... I'm always interested in the Smarty .... anybody got an answer?
Old May 9, 2008 | 10:22 AM
rjg23's Avatar
The 7-Zip dated 2008 is a beta version(nothing to do with smarty beta), I have not had problems using the beta 7zip's. I almost always upgrade mine when I need to use it again. The 2007 one is the last production release of 7zip, should be the safer, proven one to use. Once you download just open and install. You should only need the 32bit .exe, you probably would know if you had a 64bit operating system.
Once you get your smarty .7z file downloaded, simply right click, 7-Zip and 'extract here', you'll then have your .smt file to upload to smarty with smartyusb.exe
Hope that helps, There are tons of posts and instructions on mads website of what to follow on actualy getting the smarty updated. I think the 7zip was your main question.
tyroneweaver
Jan 4, 2013 09:26 AM
Totallyrad
Jul 19, 2011 07:41 AM
mikegronholz
17
Oct 12, 2006 09:26 PM
