Where can I get a T-25 VP44 torx bolt?
Old 06-18-2009, 12:56 AM
JasonblkZ06's Avatar
One of the bolts stripped out when I was installing my TST plate for my Comp wire. I got it out with an extractor, but it is jacked. I need a replacement bolt. Where can I get one of these? Anyone?
Old 06-18-2009, 09:34 PM
sheriffav8r's Avatar
Torx bolts should be available at Lowe's or HD. T-25 is not uncommon.... Just look in the parts drawers....
Old 06-18-2009, 11:17 PM
Fishin2Deep4U's Avatar
Sears will have what you need. Or Matco, or Snap-on, or Mac, ect, ect.
Dave
Old 06-19-2009, 12:33 AM
No, this is why I am asking, no one has it.
Old 06-19-2009, 06:32 AM
Ph4tty's Avatar
You need the tamper proof bit. You can get one from TST diesel and most places that sell the stealth covers.
Old 06-19-2009, 01:16 PM
JVC
JVC's Avatar
Why do you need to use a Torx bolt? How about a button head cap screw instead.
Old 06-19-2009, 04:58 PM
Mine was not a tamer proof bolt, I bought the tamper bit and didn't even need it - mine were standard torxhead. I just need a M5x.80x40mm button head bolt, allen head, torx head whatever. I just can't find one that will fit. I am thinking of just drilling the hole larger and using a standard hex head bolt. Even a bolt store I called didn't have anything.
Old 06-24-2009, 11:10 PM
I can't believe that Lowe's doesn't have an M5 .80 bolt. I'll go check tomorrow while I'm spending my child's inheritance there....
Old 06-25-2009, 02:15 AM
ALl mine had was a standard hex head bolt which will not fit unless I drill my stealth plate. I am still driving around with 4 bolts holding it on instead of 5. Next time I am in Dallas I am going to stop by Metric and Multistandard.
Old 06-25-2009, 01:36 PM
JVC
JVC's Avatar
Check out McMaster Carr.
http://www.mcmaster.com/#socket-cap-screws/=2h1bvo
Part # 91239A240
Old 06-26-2009, 08:07 PM
kevellis32's Avatar
Go to the dodge dealership.
OldSmokey
06-02-2007 02:53 PM
Timmay2
03-26-2006 06:55 PM
GatorRam
02-26-2004 10:52 PM
BPD239
03-01-2003 09:03 PM
Quick Reply: Where can I get a T-25 VP44 torx bolt?
