camshaft position sensor
Old Sep 8, 2008 | 07:54 PM
koontzy00's Avatar
two days ago started truck for about 1 hour got home shut it off. 5 mins later tried to start it but would not run. pulled fuel filter out to see if there was any fuel in canister. canister was full. put filter back in bumped starter and lp started to run and truck started. today ran the truck to work. started fine at the end of day. went to wendys to get something to eat. came out and truck didnt start. did same thing i did the other day and truck started right up. but on the way home check engine light came on and lost gauges for about 2 sec. had codes checks and said it was camshaft position sensor. my ? is would this have caused my problems of starting the other day or do i have other problems?
Old Sep 9, 2008 | 01:00 PM
Western Rammer's Avatar
Do you mean crankshaft position sensor?
Randy.
Old Sep 9, 2008 | 01:15 PM
Diesel Doc's Avatar
Randy.
Nope it would be the camshaft position sensor.
The camshaft position sensor is under the ip where the timing pin used to be. Yes it can cause a problem like that. Later 7.3 Powerstrokes are notorious for it and usually have similar symptoms.
Old Sep 9, 2008 | 05:20 PM
koontzy00's Avatar
i hope that fixs the problem. i just put a new ip in a year ago to the day. i dont mind putting a new lp on but ip wouldnt go over to well. i think that it is time to upgrade the lp anyways seems how it will already be in the shop. do you guys have any ideas on an aftermark upgraded lp? not sure i want to go to the extreme of a fass system. thanks for the help!
Old Sep 9, 2008 | 05:55 PM
chuckybones's Avatar
I had the same problem but mine was the crankshaft position sensor behind the starter, did the same thing would not start sometimes and I lost rpm for a few minutes. I replaced it and so far it has been fine.
Old Sep 9, 2008 | 09:10 PM
smokewagon's Avatar
i also had the problem that you had mine was also the crankshaft sensor behind the starter but the gear grenaded in the oil pan so you should be able to just change the sensor and be back running back to normal
Old Sep 9, 2008 | 10:28 PM
Diesel Doc's Avatar
You could go with the fass hpfp if you do not want the whole system. A full big line kit will help also.
supercharged_hp
Oct 29, 2008 03:34 PM
curts99
Mar 31, 2008 08:20 AM
efrantz
Apr 30, 2007 07:03 AM
hellwig333
Aug 23, 2006 09:24 PM
SilverRam01
18
Nov 28, 2005 11:54 PM
