A/C parts numbers?
Old Jul 4, 2008 | 03:59 PM
Machinos's Avatar
A/C parts numbers?
My truck came without A/C. I got a condensor and heater box thing (the big plastic thing that the A/C and heater lines run into, that sticks into the cab) off eBay over a year ago, but don't have the rest of the parts for the conversion.
Is it possible to get the rest of the parts from say, NAPA? Honestly I don't even know exactly what I need - I don't have a donor truck and A/C stuff is kind of beyond me. I assumed it couldn't be too hard though since universal A/C kits are pretty common in the old-car scene.
Any help is appreciated!
Old Jul 15, 2008 | 12:15 PM
samiam4's Avatar
Machinios,
I'd really recommend looking at the missing factory pieces as an option. Find a junkyard and get controls/computer etc needed. In bigger cities Pick-your own parts are popular and great for projects like this.
The compressor may need a bracket which you could buy new from Cummins cheap. Being a 90 model, I'm not sure if factory hoses are available new-they are for the later models. A new aftermarket condensor is $100, and you'll need switches, dryer, etc. For all that work I'd do a new evap and heater core while you have it apart.
You should try and get the Sanden compressor and not a China made knock-off. I think dealer wholesale is $300 for a new one.
The other approach is to get an aftermarket under the dash unit and just do the compressor/bracket factory. Those universal deals look cheezy. Then you can take it to a hose builder and they can make metal/rubber hoses to go between the parts.
Think it through in advance so you don't waste $$. Ie do you want to put an intercooler on it later? IF so, now's the time to get a used radiator support and use the later model condener.
Michael
Old Jul 16, 2008 | 12:20 AM
stackx2's Avatar
here you go found this in the sticky hope this helps
system specs R-12, refrigerant capacity 44 oz., oil capacity 4.6 oz for 93, 7.25 oz for 92-89
blower motor w/ A/C 35474
blower motor w/o A/C 35560
93-92 SDB709 type compresor w/ clutch S57562
91-89 C171 type compressor w/ clutch 57106
non-intercooled condenser 53298
intercooled condenser N/A
evaporator core 54108
expension valve/orifice tube 38849
intercooled fan clutch 36936
non-intercooled fan clutch 36705
filter drier/accumulator 33555
heater core w/ A/C 94619
heater core w/o A/C 94600
93-90 tensioner assembly 45844
89 idler pulley 45981
clutch cycling switch R-12 35800
clutch cycling switch R-134a 36677
coolant temp sensor 36425
low pressure cut out 35752
water outlet 85181
tranny coolers:
Ultra-Cool
light duty 53000
medium duty 53001
heavy duty 53002
Rapid-Cool
light duty 53005
medium duty 53006
heavy duty 53007
nbaggett89
Dec 26, 2015 09:36 AM
sCreamin400
Nov 2, 2008 01:46 PM
CTD_Neil
Jul 19, 2005 08:13 PM
Jim Coleman
Feb 2, 2005 05:03 PM
NOTSTK
Apr 11, 2004 10:42 PM
