i/c core support in a non i/c truck....
i'm sure an i/c core support would bolt right into place on my '90 but what things could i potentially run into? will my radiator fit and bolt in just like it does on my existing core support? i found a deal for one from a '93 for $100 and i think that's a good price.
the radiator mount was the first thing that came to mind and just what i was afraid of. could brackets be assembled in order to make it work? i've got the i/c grill set up already, just need to buy the parking lamp assemblies. i figured it'd probably be easier to just buy the support rather than having to mod mine by moving the headlights.
i know where an i/c radiator is that i could have. i had trouble finding a thermostat housing in the past and have considered just building an upper hose with a 180* piece of pipe at the thermostat housing and a 90* piece at the neck of the upper tank. not sure what that would end up costing, but probably worth just buying a thermostat housing if i can find one. haven't had any luck finding one at automotive suppliers like napa or autozone. i don't think i've checked rockauto.com yet.
I've wondered what the difference is between the 1st gen and 2nd gen t-stat housings. They look almost the same on the pics I have saw and if they are check Redliner on Ebay they always have a couple of the housings from a 2nd gen 12v.
sounds like in the long run i'd be better off just moving my headlights. might end up costing a little less to do so. and since my intercooler mounts differently too, it might be best to just leave it as is.
blueghost08
Dec 16, 2014 08:23 AM
