Bully Step Bar Installation Help
Old 06-27-2008, 03:45 PM
austin1972's Avatar
2006 Quadcab -
I got the stepsides and went to install them but didn't get too far...I removed the body bolt underneath to attach the mounting bracket and the washer on the mounting bolt is too big to sit flat! Has anyone else had this problem with these steps? I really don't want to alter anything (grind down the washer to just 'make' it fit.
Bully hasn't replied to my messages...
Thanks in advance!
Old 06-27-2008, 03:50 PM
ahopper's Avatar
did they give you new body bolts? i did my gandfathers mega cab and it came with new longer body bolts but i belive they were smaller washers. i know i didnt have a problem with them sitting flat
Old 07-14-2008, 04:49 PM
jasonstacked06's Avatar
i had that prob i had to do some rigging and make a braket and use washers and stuff . fyi mine only lasted about a year and a half and broke off they corroded reall bad the bracket part that goes around the tube step so just be careful you dont bust you butt.
realtreehunter
04-03-2011 01:08 AM
CLeger67
04-07-2008 08:17 AM
Diesel-Dan
17
08-04-2006 09:51 AM
Quick Reply: Bully Step Bar Installation Help
