bully dog exhaust
bully dog exhaust
has anyone tried the full 4inch bully dog exhaust, it is a tiny bit cheaper than stans and has free shipping, and it looks to be the same thing! im needing a new system soon and i want the best fitting/flowing exhaust out there.
to check it out go to autopartswarehouse.com, and just type in the info needed! im needing some help,
thanks guys!
thanks guys!
4" downpipe is not necessary until you NEED it, which would be when you step up to a 4" turbo outlet such as a s300 or hx40, JMO. SAVE your money. No way I'm spending near $600 for exhaust. I'd get two of the Big E brand kits at that price.
Im bout to build my own 4" dp. I had one 4" 90* from a former exhaust config, and just got another one + the flange in the mail today. Those and 12-18" of pipe will get it there.
hey randy do you plan on making your own full exhaust, if so how are you going to get the bends over the rear axle and thru the t-case? if you get this figured out when i move up there we r gona throw one on mine
Try RPMoutlet.com they have Motoblue systems pretty cheap. I have the 4" duals and Fiveology just put on the same system. Pretty cheap too.
I got the Aluminized system. Not rust and 2.5 years on it.
Ive already got 4" from the bottom of the dp. I got my system out of oklahoma when I was 16. The dp is 3 though. You could easily fab up an exhaust though. Find a 4" tailpipe from a 3rd gen, and hack/reweld to get it to fit. Im 2wd so not sure bout tcase, but mine is pretty much a straight shot from dp to axle, with only one slight bend in it. Let me do some checking, I think I can scrounge up the stuff to do one for real cheap and we could fit it on your rig once youre up here.
I priced stuff to build one. This is just if you cant find pipe to build one-shop around your local exhaust shops. I priced 10' of 4" tubing, 2' of flex, which might get you around the t-case, 3-45* elbows for over the axle, and 2 90* elbows for the dp. For the dp flange, you can either reuse yours or I have one I can probably contribute to the cause. Shipped this stuff was $270 though. Seems kinda high, but I dont know what Stans gets shipped...
well maybe if you decide to fix your up and redo it, i can get your old pieces, my egt's are good so i was think for now a straight pipe after the t-case and leave the dp and thru the t-case stock, just a thought, we will work it all out we can proab round up some scrap, do it and maybe do a write up
