Broken Banjo bolt on VE Pump
Through a series of bad events, someone (not I) overtightened the banjo bolt on my VE Pump, and snapped it. Where it got really bad is that I put both of the pieces in my pocket and took to work, planning to stop by napa on the way home. I learned the hard way that I have a hole in my pocket. Does anyone know the specs on the banjo bolt on the VE pump so I can get one?
That's not a normal banjo bolt, that is a flow restrictor. If you put a standard banjo bolt in there the truck will run like doo-doo.
You need to visit a Bosch pump shop, they can help you out.
Dieseldog800
Sep 2, 2006 11:56 AM
Livngood
May 11, 2005 10:05 AM
