Brakes
Old 04-15-2006, 10:22 AM
Yamadad's Avatar
Brakes
Ok, it's time to do my front brakes. I want to replace the rotors, but it seems easier to replace the rotors and hub assembly, plus according to the manual it's time to replace my front wheel bearing. The dealer wants a mint for the hub assembly with rotors. They say it is a dealer only item, but I've seen something that might be it, made by Warner on the web. So, are there any aftermarket sources (for less)? Or can I pull the hubs and rebuild them easily?
TIA
Old 04-15-2006, 10:48 AM
Partsman's Avatar
The wheel bearings are the hub. Yes you can get the wheel bearings and rotors aftermarket. The only thing you have to do is drive your studs out and reuse them to put the 2 together(unless you buy new studs too).
wildcargo
11-29-2005 04:20 AM
95black2615
08-22-2005 09:21 AM
JImbo1
13
04-18-2003 06:44 AM
Quick Reply: Brakes
