Brake rotors
Old Jul 15, 2009 | 11:06 AM
Falcon1's Avatar
Brake rotors
Ok mine are warped. There is 3 different rotors made for these trucks which one is it? Where do you find the rotor casting number? Are these 4500# or 3500# axels?
Front; 4500 Lb Axle; Rotor Casting Number 99756
Front; 4500 Lb Axle; Rotor Casting Number 100353
Front; 3500 Lb Axle; 8 Stud Rotors
Old Jul 15, 2009 | 11:12 AM
jimbo486's Avatar
nothing wrong with overkill. i'd get the 4500's. i think that's what you need anyway. not sure on the casting number, but maybe try near the center around the hub bore and studs.
Old Jul 15, 2009 | 11:14 AM
92roughstock's Avatar
It's a 4500# axle for sure. I bet one is for SRW, the other for DRW.
Old Jul 15, 2009 | 11:16 AM
Falcon1's Avatar
On the removal of the rotor will it come off easy or do I need to pop out the studs?
jimbo486's Avatar
don't know that a drw or srw would matter. i'm sure the rotors would be the same cuz with a drw you'd just have to bolt the adapter to it.
Old Jul 15, 2009 | 11:39 AM
12valve@heart's Avatar
Check the sticker on the drivers door post to see which axle you have.
Old Jul 15, 2009 | 11:41 AM
Don't know on the W series but on my D250, I had to press the studs out and then separate the hub from the rotor, then press it all back together.
Old Jul 15, 2009 | 11:56 AM
Thunderhog's Avatar
Different, don't ask how I know.
Old Jul 20, 2009 | 09:34 PM
samiam4's Avatar
Has anyone tried the Brembo rotors or drums? With all the talk of China made parts.. they use to be well respected on imports.
M
Old Jul 21, 2009 | 08:53 AM
Thunderhog's Avatar
M
Do they even make them for our Trucks? It is getting more and more difficult to find parts for these things.
Old Jul 21, 2009 | 09:01 AM
Falcon1's Avatar
Got it done
Thanks for all the input, really wasn't that bad, while I was there I replaced my stearing gear box that was leaking sence I put on the new stearing shaft a year ago and found that the drag link was wore out and replaced that also. Almost all new parts up front now should be good for a while, Still better than truck payments................
Old Jul 21, 2009 | 11:38 AM
jimbo486's Avatar
ssbc makes drilled and slotted rotors for our trucks. you can have them for about $150 a rotor though . probably well worth it performance wise
04ctd
Aug 3, 2007 04:19 AM
AZGEARPRO
Jun 4, 2004 11:31 PM
towin1JT
Oct 29, 2003 08:51 AM
DieselRamMan
Oct 7, 2003 09:38 PM
Madoco
Aug 13, 2003 09:42 PM
