Bought a Diesel, Now What?
Read your manual (by some of the questions on here some definitely don't), don't mod a DD, and drive it.
Do a bunch of searching and reading on here to answer 99% of your questions. Each question has a 100 opinions, read up and make your own descisions.
Cya
Cya
Ok ok, since my sig is not up to par. Here you go.
2004 QC (Quad Cab)
4x4 (Four Wheel Drive)
48RE Auto (Automatic Transmission)
3500 (Dodge's way to lable a 1 Ton Truck)
SRW (Its not a dually)
325 HP
Oh, I almost forgot its got a CUMMINS Turbo Diesel.
I am in Saint Robet, Missouri and I am moving to Columbus, GA in May.
Thanks guys.
2004 QC (Quad Cab)
325 HP
Thanks guys.
If I had your truck, I would simply put some 33 or 35's on it since more than likely you have 4:10's for your gears which should bump up your mileage. Enjoy it, I kinda wish I had an 04 instead of my 05.
Wood
Wood
I would highly recommend the flash for high idle control using the cruise buttons. Are you able to lockout overdrive when towing?(On my 05, I had to have this flash- I don't know if it was the same onthe 04.5??) I added non restrictive mufflers on both my 03 and 05- lower egt's when towing.
2004 QC (Quad Cab)
325 HP
Thanks guys.
2004 QC (Quad Cab)
325 HP
Thanks guys.
Dang, I really need to pay attention more. Sorry
What is the high idle used for on the truck?
Thanks, Jeremy
