Boost pressure
Old Mar 6, 2010 | 11:36 AM
Hothead2500's Avatar
Boost pressure
I just installed some gauges, and I'm having a prob with the boost pressure. I'm only getting 13 when I when I'm floored and only 3 or 4 when regular driving. I still have about 2 or 3 feet of extra hose that I did not cut off. Not sure if that has anything to do with it. If someone could help that would be great.
Old Mar 6, 2010 | 11:41 AM
Dinner's Avatar
Where did you tab in for boost pressure? What brand of gauge did you go with? Does your truck smoke quite a bit, seems to me it will be a boost leak or the gauge is faulty. Unless your HX/HY is wore out, but I doubt it...
Old Mar 6, 2010 | 01:13 PM
I tapped it on the intake horn. They are autometer gauges. No she does not smoke, only if I make her.
Old Mar 6, 2010 | 08:47 PM
Mike Holmen's Avatar
The Guru
Stock you should see at least 20psi of boost. I agree that 13psi of boost sounds odd. Hate to ask, is your boost guage still working?
If you have no boost leaks, I would guess that you have a very weak VP pump. No smoke? How does the truck start? Whats you fuel pressure at the injection pump?
Old Mar 15, 2010 | 12:13 PM
I'm taking the truck on the 22nd to see if there r any boost leaks.
Old Apr 1, 2010 | 12:59 AM
totalloser's Avatar
Boost leak, preturbo exhaust leak, or not enough fueling.
Damaged turbo possibly, but normal wear causes oil leaks, not low boost. Damaged turbine wheels can cause low boost. Bad wastegate usually causes the gate to stay closed due to the spring.
I'd be tempted to slip in another gauge to verify it's not a faulty gauge. www.surpluscenter.com has gauges for a couple bucks for a simple test.
HOHN
45
Oct 8, 2005 08:51 AM
triplenickel
Aug 23, 2005 04:01 PM
GTSDave
Jul 8, 2005 09:06 AM
MY WORLD
25
Dec 29, 2004 08:54 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
