Block Heater
Old 01-23-2008, 02:48 PM
223 rules's Avatar
Block Heater
Do the engines come with one already installed and all you have to do run the power cord or do you need to install the whole thing. I ran into a guy that had either an 06 or an 07 and he said that he thought that the truck had one and all you had to do was attach a power cord to it.
Old 01-23-2008, 02:52 PM
With age comes the cage
Colo_River_Ram's Avatar
yes it comes on the truck..if you buy the cord from dodge it is 62 bucks if you buy it from cummins it is 15 bucks
Old 01-23-2008, 02:58 PM
texbeer2's Avatar
The block heater is in the motor when built. The cord is a $10 option. I just ordered mine and it shows up on the build sheet but didn't cost anything. Hope the dealer didn't mess-up. Dodge sells just the cord but don't know the price.
Old 01-23-2008, 03:00 PM
texbeer2's Avatar
Colo River Ram types faster than I can.
Old 01-23-2008, 03:02 PM
223 rules's Avatar
Where is it located on the motor? There is a cummins shop about a mile down the road from me. Thanks
or is that Half-Faster
Old 01-23-2008, 03:03 PM
Above the fuel filter as i recall..
Old 01-23-2008, 03:05 PM
Truckman0097's Avatar
Plugs into the motor behind the oil filter on the passenger side. there should be a screw in cap there now, just remove that and plug in the cord.
Check this out... it has a pic.
https://www.dieseltruckresource.com/...eater+cord+pic
Old 01-23-2008, 03:33 PM
223 rules's Avatar
Can any of you give me a cummins part number. I went to the cummins dealership and the parts man said they couldn't look up the engines that are in the dodges as they are locked out of those but they can look up part numbers. The cord that the book showed was $15 dollars but they didn't know which heater it would work with. Thanks
Old 01-23-2008, 04:26 PM
spider_1954's Avatar
You can lay on the ground and remove the cover and install the cord with no problem then just run it along the frame towards the front of the truck.
I got mine off of ebay for cheap
Old 01-23-2008, 09:33 PM
ChrisM55's Avatar
ALL THE CORDS ARE THE SAME. yOU SHOULD NOT NEED A PART #. I went in a couple of days after getting my 08 and the guy just grabbed one off the shelf. Worked just fine.
Sorry bout the caps
Chris
Old 01-24-2008, 01:12 PM
davidj54's Avatar
Just tell them it's a common rail ISB and they'll know what you want. I removed the air duct and it was very easy to reach. I routed it along the battery cable then around the airbox and dropped it in front of the bulkhead. It's really accessible and hangs out of the way when not plugged in.
Old 01-24-2008, 07:00 PM
amesff01's Avatar
Check the classifieds on this sight, I got mine there to my door in 5 days for $17. The plug should be round with two holes, and a metal tab bent over the edge. It should all be held in place by a ring that compresses it in to the hole. It took 5 minutes to put it in from under the truck and zip tie it on the frame to the front bumper.
Old 01-25-2008, 06:49 AM
223 rules's Avatar
I went by the dealership to see what the cord cost since I was driving right by it to just see what they would want for it. The parts lady said it was 82 dollars. I asked her if I looked like I walked in with a jar of vaseline in my hand and walked out.
Old 01-25-2008, 01:30 PM
beers_52's Avatar
I just did this install a few days ago.
Top view, plastic cap removed:
Bottom view:
Installed, looking from the firewall foward. Turbo inlet hose in foreground.
Hope that helps!
-Bill
Quick Reply: Block Heater
