Biting the bullet
Old 11-19-2008, 02:03 PM
robert78.5's Avatar
Biting the bullet
As much as i hate to purchase a VP44, i ordered one today, the warm start problem is not getting any better now with winter fuel being used. I am just hoping that the problem will in fact be in the pump, not some electrical problem.
Old 11-26-2008, 10:51 PM
robert78.5's Avatar
OK , 10 days later and my pump should be here by tommorrow, Purolator sent it from Alberta to Toronto than back to Manitoba, go figure. Now, when i install the pump do I have to get any programming done or should it calibrate and run ok on its own?
Old 11-26-2008, 11:04 PM
br2500ctd's Avatar
Swap out the pump and you'll be fine. No calibration needed.
Old 11-27-2008, 01:10 AM
WestTN's Avatar
Did you check for codes before deciding the VP was bad?
Old 11-27-2008, 08:05 AM
robert78.5's Avatar
Yes numerous times. Nothing major. P0234 Boost pressure, P0500 speed sensor , P01693,??? Just getting hard to start when engine is warm and running winter fuel . I am thinking with the high mileage (500000 Kms...312599 Miles)it is time to change it. I am not sure if it is original or not as I bought it used.
MOAGGIE
08-07-2009 06:16 PM
texhand
02-09-2008 07:56 AM
Rauschbo
17
11-22-2005 07:40 PM
Shovelhead
09-19-2003 08:52 AM
Luke S
05-15-2003 01:50 AM
Quick Reply: Biting the bullet
