Bio-diesel And Additives
Old Feb 25, 2008 | 06:06 AM
chipmonk's Avatar
have been reading a bit about the use of different % of bio-diesel, as well as home brews and svo, and many are recommending the use of an additive called 'ldl' (longer diesel life) with any bio's. they say that bio's have a higher instance of bacteria and fungus, and a shorter shelf life than 100% petro, and ldl will help with these, and other issues. i've been using ldl in my last 2 ctd's as my regular anti gel/injector cleaner fuel additive, and it's worked real well for me. thought this might be interesting for anyone who is running, or considering running any bio.
Old Feb 25, 2008 | 08:56 AM
mikewalling's Avatar
I have never heard of the bacteria problem in vehicles that get used. Mostly in boats and tractors and equip that has been sitting. The bacteria thrives in the interface between water and fuel so keeping the tanks full helps.
When you add Biodiesel to an old tank it may "clean it out" in a most inconvenient way. Be ready with a few fuel filters. Pure Biodiesel cleaned the scale off the inside of my ford tractor tank and I had to drain the fuel twice and rig a makeshift pre-filter. I haven't used an additive. I have been storing my Biodiesel in a poly tank through 2 winters with no obvious problems.
Old Feb 26, 2008 | 01:08 AM
chipmonk's Avatar
from what i've read, bacteria will grow more easily in trucks running bio, especially in warm, humid weather.
Old Feb 26, 2008 | 10:14 AM
Chipmonk, I would be interested in reading what you read. Any idea where you found it?
Old Feb 26, 2008 | 12:26 PM
chipmonk's Avatar
one of the places was freedomfuelamerica.com. there are several others that i found by doing searches for 'bio diesel' and 'longer diesel life'.
Old Feb 26, 2008 | 01:43 PM
DBLR's Avatar
If you get an algae problem then all you do is add an additive to kill it off.
justen920
May 14, 2009 12:52 PM
donhov
Jul 5, 2007 07:42 PM
merrillr4
Nov 18, 2006 12:42 AM
my02CTD
13
Nov 3, 2006 08:42 PM
tfarmer96
May 4, 2005 09:59 AM
