Bearing Noise
Old Dec 27, 2005 | 11:11 AM
RowJ's Avatar
Bearing Noise
It's either the Drive Shaft Carrier Bearing or a Front Wheel Bearing. Intermittant RPM noise based on ground speed of the truck.... not engine rpm's.
Anyone had to replace wheel bearings at 90,000 miles?
RJ
Old Dec 27, 2005 | 11:19 AM
zukgod1's Avatar
Still could be a Wheel bearing.
Jack up the front end and check it like you would a ball joint or tie rod end.
maybe spin it by hand and have someone listen, do each side for compairison.
check your U Joinst as well, I've seen them cause some funny noises.
dan
Old Dec 28, 2005 | 07:30 AM
RowJ's Avatar
I'm just starting to get a noise....it's not all the time.
Guess what I'm really asking is How many miles are members getting out of front wheel bearings on 4x4's?
RJ
Old Dec 28, 2005 | 07:37 AM
crobtex's Avatar
I thought mine had a noise coming from the right front, but it turned out to be the right rear wheel bearing and race. Had the seal, bearing and race replaced and all is quiet.
pmtg
Jul 19, 2007 08:47 PM
Rattletrap1
Jul 11, 2007 12:12 PM
wadecool
Jan 12, 2007 11:39 AM
Joseph H. Smith
16
Jan 6, 2007 08:13 PM
