Banjo Bolt Crush Washers
Old May 28, 2006 | 11:55 PM
capt.Ron's Avatar
I think I can... I think...
I had the banjo bolts off of the filter housing last week and replaced all the bigger crush washers but the not the smaller ones that are one the small line on top the inlet line. Now it looks like I'm leaking fuel from those crush washers.
I need the cummins part number for those smaller washers if anyone knows it.
Old May 29, 2006 | 12:49 AM
Hemi Cat's Avatar
Generally you can reuse those seal washers several times before they get shmushed out to where they leak unless there is a bit of dirt on them. I would try removing them and spray things down with brake/parts clean or good ole wd-40, then reassemble it. watch your torques so you don't snap the bolt, spec is 6 lb/ft torque. easy to snap and will leak if dirty.
Old May 29, 2006 | 10:29 AM
capt.Ron's Avatar
They may be dirty but I lost one and ended up digging through a drawer and using an old one that wasn't neccesarily made for that application so I would like to get the correct and new washers for this line. I had the new ones for the larger line on that side as well as the larger one for the outlet line. I need the little ones for the line on top of the inlet line.
What is that second line for? It runs around behind the head, just not sure where to?
Old May 29, 2006 | 01:46 PM
Hemi Cat's Avatar
The small line on top of the rear line fitting (filter inlet) is for the injector return fuel. The foreward line (filter out)goes to the inj pump and has the air bleed screw on top. I don't have part numbers, but would suggest taking the banjo bolt with you and go to a cummins shop to make sure you get the correct ones. Most diesel repair shops will have an assortment to choose from. I NEVER throw away unused gasket washers and put them in a drawer just for times like you are having. My kids have really made fun of me for keeping "junk" around, but have humbled themselves and meekly asked for items of "little value". Now they are worse pack rats than me. Good luck
Old May 30, 2006 | 10:17 AM
Mark Craig's Avatar
capt.Ron,
Cummins part number:
3963983
Mark @ DPPI
Old May 30, 2006 | 12:54 PM
capt.Ron's Avatar
Originally Posted by Mark Craig
capt.Ron,
3963983
Mark @ DPPI
Hmmm I just got back from the Cummins dealer and they gave me 2 washers with Part #3918188.
I haven't put them on yet but they look like the right size.
Old May 30, 2006 | 04:28 PM
capt.Ron's Avatar
Well they fit and there's no leaks.
That's Part #3918188.
Fits the small banjo bolt that screws into the top of the rear(inlet) banjo bolt.
97catintenn
Jul 15, 2010 05:46 PM
schamran
Apr 9, 2010 08:12 PM
RenegadeT
Mar 17, 2010 10:10 AM
marine4life
May 19, 2006 10:23 PM
marine4life
Mar 30, 2006 05:55 PM
