ball joint replacement
Old 11-26-2006, 10:12 AM
trex's Avatar
i have someone replacing my ball joints and now im worried after reading some threads. He wants to remove the whole a-arm assembly to remove the ball joints in a vice. he was beating the old ones out with baby sledge and it wont budge. is it a good idea to remove that much of the front end?
Old 11-26-2006, 11:23 AM
DL1221's Avatar
Yes, the easiest way to change ball joints is to remove the A-arms, but don't beat the ball joints out with a hammer, and absolutely do not ever, ever beat the new ones in with a hammer. Take the A-arms to your local machine shop and have them press the old ones out, and the new ones in. I just did mine and it took one hour and $10 for the shop to change the joints.
Now there are small ball joint presses (they look like big C-clamps) that can be used to remove and install the ball joints with out removing the A-arm. You can rent these at your local parts store. Here is an example of one:
http://www.harborfreight.com/cpi/cta...emnumber=38335
Again, don't beat the new ball joints in, if they get damaged you could seriously compromise their integrity. The other advantage to removing the A-arms is that you can inspect and change the bushings. Mine wire all torn up, so I replaced the ball joints and bushings at the same time. Probably the most common, and the best, aftermarket ball joints to use are the Moog ones. I've heard some bad stories about TRW ball joints.
Old 11-26-2006, 12:10 PM
torquefan's Avatar
Keep in mind it'll DEFINITELY need an alignment when it's done. It'll probably be right out to lunch.
Old 11-26-2006, 06:54 PM
dslpower's Avatar
Its easier to remove the arms like DL1221 said to replace the joints. Some have tack welds on them holding them in from the factory, so pounding with a sledge is likely to bend something.
72dart
06-19-2012 10:42 PM
Wulzcat
12-19-2009 05:15 PM
wcbcruzer
22
04-30-2008 06:58 PM
FDC
07-16-2007 12:51 PM
Treangen
05-07-2007 03:10 PM
Quick Reply: ball joint replacement
