Ball joint castle nut size?
Old May 24, 2007 | 11:41 AM
Paul Winey's Avatar
Does anyone off hand know the size of the castle nuts for the ball joints on a Dana 60? I'm at work and want to pick up everything I need before heading home and tearing it down. Hate to have to walk to NAPA tomorrow
Thanks for any help.
Paul
Old May 27, 2007 | 07:56 PM
CanuckCTD's Avatar
They are 34mm. Just did my ball joints this weekend. Very simple once you have all the tools and air. Once I removed the four bolts from the back of the rotor, used a couple of chistles to loosen the whole assembly and the rotor, bearing and axle shaft came right out. Took it to a shop to have the bearing pressed out and inserted into a new rotor and replace the u-joint. She is now back together and working great, next stop is a wheel alignment.
EPCO
CODTR #26
Jan 19, 2011 08:14 AM
wcbcruzer
22
Apr 30, 2008 06:58 PM
CanuckCTD
Jul 9, 2007 05:58 AM
Goober
May 11, 2007 08:20 PM
lews930
Feb 6, 2007 05:49 PM
