back end noise
Old Aug 13, 2007 | 04:47 PM
siver19's Avatar
back end noise
My truck started making a screeching noise when in reverse. But now its doing it in drive. Can't pinpoint seems to be making the noise in revolutions with the driveshaft. Doesn't really sound like metal on metal, more like a dry rubber seal. Any help would be appreciated, thanks in advance?
Old Aug 13, 2007 | 07:15 PM
OOPS's Avatar
Set the rear end on jackstands with the rear tires off the ground. Block the front wheels. Start it up and put in gear. See if you can isolate the squeak.
Old Aug 21, 2007 | 04:30 AM
rogerL1961's Avatar
u joints when bad will make a screeching noicse.
Does the noise go fast the faster you go.....
Old Aug 21, 2007 | 05:19 PM
gcssr's Avatar
check your rear brake pads for wear. some had a metal wear tab that would scrape when the pads wear down
Grant
Old Aug 21, 2007 | 09:54 PM
X-Banks's Avatar
I had this problem with my 2003 and it was the rear u joint.
Captum
Mar 14, 2010 06:06 PM
Jordan5687
33
Feb 16, 2007 12:37 AM
Ridiculous
Mar 5, 2006 07:13 PM
JoshPeters
Apr 3, 2005 08:13 AM
Rumbles
May 24, 2004 02:26 PM
