another water injection question
Old 07-30-2009, 05:03 PM
gsbuick65's Avatar
I got one on my truck tapped into intake, its just a on or off type no progressive, works fine when the truck is empty, I can fell the truck pick up when it kicks in. but when I put my camper on and the meth kicks in the truck starts to miss real bad. in mixing meth with water 50/50. whats the deal?
Old 07-30-2009, 05:45 PM
Ace
Ace's Avatar
What size nozzle and what boost psi is it starting to spray?
Don't run it like that too much.
Old 07-31-2009, 09:53 AM
DTR 1st Sergeant
soulezoo's Avatar
Two things could be happening. One, too much water is putting out the flame.
Two, too much meth is causing detonation.
Try cutting back to 1/3 meth, retard timing a little if possible and maybe smaller nozzles.
You are going to have to play with those perameters and find what works best. Don't continue to run with that "miss"-- you could really hurt something.
Old 08-01-2009, 02:46 PM
lcaad1249's Avatar
Nozzle could also not be screwed in far enough and not misting the mixture properly.
Old 08-02-2009, 12:33 PM
gsbuick65's Avatar
sorry took so long to get back, I didnt get a notice , have a 800cc nozzle set to come on @ 20psi.
Old 08-02-2009, 12:35 PM
gsbuick65's Avatar
It only does it when I have the camper on the truck, works fine empty, I added some water see what that does.
Old 08-02-2009, 04:05 PM
trik396's Avatar
What year is your truck?
Old 08-02-2009, 05:55 PM
gsbuick65's Avatar
opps, thought it was i sig, 2005
Old 08-03-2009, 02:51 AM
trik396's Avatar
Fuel pressure Ok?
Fuel filter clean?
A lot of variables but as stated, ease up on the meth usage. I don't know about the timing with your Hypertech stuff but if it's adding timing and you're spraying meth, you can blow a headgasket or worse pretty quickly. Without studs I wouldn't spray anything, imho.
Old 08-03-2009, 09:46 AM
Ace
Ace's Avatar
Sounds like too much timing if it's only happening under load.
Old 08-03-2009, 10:24 AM
DTR 1st Sergeant
soulezoo's Avatar
I agree, but think it is only part of the issue which is why I phrased the response like I did.
I really think that as he needs/adds power, then there is more fuel and he gets to a point where there is too much timing AND meth and that is when he reaches the threshhold. With only one 800cc nozzle, it is not putting a ton of water out, but with that large a nozzle and not knowing the psi of the pump, it may not be atomizing well either.
My recommendation is like I said above, cut the meth down to 1/3 (maybe even 1/4), and dial back some timing.
Old 08-03-2009, 11:57 AM
gsbuick65's Avatar
how do you dial back timing?
Old 08-03-2009, 12:02 PM
DTR 1st Sergeant
soulezoo's Avatar
I am not familiar with your hypertech tuner... but there should be a tune that will go without timing or lowered timing. If not, you have only two choices. First is the tone ring mod (do a search here to find it) which will allow you to manually dial out some timing or second, keep diluting the meth down until the miss goes away.
Old 08-03-2009, 12:20 PM
Ace
Ace's Avatar
I'd consider investing in a progressive controller for the spray, as well.
Old 08-03-2009, 01:20 PM
WUnderwood's Avatar
and try spraying straight water
Quick Reply: another water injection question
