Air helper systems
Air helper systems
Hello all...
Does anyone have an opinion on Ride Rite or Timbren air springs...
I am looking at killing the sag when heavily loaded and don't want to compromise unloaded ride and axel travel. I am worried that Ride Rites limit axle droop and Timbrens make unloade ride harsh and unloaded upward flex limited...
Thanks in advance for yuor opinions...
Re: Air helper systems
Originally posted by cquestad
Hello all...
Hello all...
I think that is http://www.airliftcompany.com/
I've had firestones on my rig for ~1.5 years. My truck came stock without helpers, and with a 1250 lb flatbed on them all the time after already 200,000 miles of use, they were useless pulling our trailer.
I put the airbags on and never looked back, and use them almost daily (I mean as far as carrying a load). The unloaded ride isn't much worse than just springs, but remember I'm carring the weight of 2 pick-up beds on them.
I have thought about making guides so they can float above the axle when I don't need them, kinda like regular overloads, but just haven't had the time.
The only downfall to them is you have to keep at least 10psi in them, or the shock from going from 0psi to 10psi over a bump can blow the seals. I've also thought about running a dump valve like a semi the let the pressure escape into the atmosphere without hurting the seals.
Whoops, now that I've finished my book, I hope I've said something helpful
Chris
Chris
Guest
Posts: n/a
I read some bad press on them early on. It had to do with not enough compression space available and therefore limiting wheel travel that way. In my case I run a leveling kit so I add air anytime there is a load, this keeps enough room for the bags to compress while driving. Eventually I installed a set and have been very pleased. I can feel a bit stiiffer ride with no load and minimum inflation but not bad. I use my truck off road quite a bit. Limited droop has not been a problem. I've gotten it crossed up pretty good retrieving game without incident.
On our d-max the air springs help level out the truck, (6" procomp lift) but the ride unloaded is very stiff for a 2500. w/ our 35' trailer (contains two four wheelers) the ride is much better w/ about 80 psi in each bag. Unloaded the truck is very stiff, bumps cause the back end to be all over the road.
I ran the Firestones on the back of my Tundra and they worked fine, you keep 10 psi in them un-loaded and the ride was not harsh. I built my own compressor system for it out of a Cadillac air suspension compressor and that also worked great. This is hearsay, but I have been told that there are a lot of problems with the Air-Ride system, but like I say that is hearsay.
Firestone Ride Rite
I have been running the Firestone Ride Rite on both my '89 Ford F-250 Supercab 4X4 and my '03 Dodge CTD QC Ram 2500 4X4. Personally I think they are a great investment as I can level my load, which the Timbrens do quite give you that option. My Dodge I have added the Dual Command air control in the cab so I can adjust the air bags anywhere and it gives an air compressor to use to fill up air toys and re-inflate tires when I have had to drop the pressure in them for sand out at Port O'Connor, TX. I make consider the Timbren for the front axle of the Ford as it is sagging a bit, if I do not actually end up replacing the front springs. I purchased my Dodge kit from www.truckspring.com; they also handle Timbren. You might give them a call they have been very helpful to me.
L8r,...........dogger
I installed a set of Ride Rites with compressor and 1 gallon tank to help with the camper. My compressor is mounted to the rh fender in behind the battery. There is a big thick bracket there that I drilled and tapped (had to use an angle drill) then I just screwed the supplied #10 machine screws. It was an ignorant spot to work in, difficult to hold the compressor and start the screws but it went in. It should stay nice and clean and cool up there. I just oriented it in such a way that the filter could be accesed for periodic cleaning. My tank is mounted to the top of the tranny crossmember on the lh side, the member is u-shaped which had to be built up flat with a small piece of aluminum plate to allow the tank's mtg pad to work. I also didn't like the switch/gauge panel that came with it so I junked that, it was too bulky and clunky. My gauge now lives where the cig lighter used to, and the switches or valves whatever you want to call them are in the panel below the steering wheel, basically centered. I installed a schrader fitting on the drivers side firewall to allow easy access to attach the air hose. You can't do much with the air that little compressor will supply, but it's fine for tires, air matress's or toys at the beach. Overall I like the set up, alomst a year, zero leaks. Also having the ability to level front to back and side to side is slick. It took me about 5 hous to do everything, but i wqs quite picky. Just the bags shouldn't be but an hour, if you went with bags alone and not the compressor I would suggest a $30 cigarette lighter compressor it's nice to be self contained. One last thing the onboard controls rule, I learned last year going to the coast elevation has a big impact on air pressure. One minute it's all good, then you climb a few thousand feet and it's like you have no rear suspension!
edit; If you choose the white face gauge, it's like they're made for our trucks. An excellent match!
The ride rites sound the way to go but:
Will the bags be damaged when I am REALLY crossed up four wheeling...
and
With the minimum 5 psi in the bags...does the ride feel worse unloaded?
and
Guest
Posts: n/a
As per my post above:
I've been crossed up in ravines bad enough to have sage brush dangling from the bumpers on opposite corners. In the process I'd have kitty corner wheels dangling in the air. I'm a four-wheeler from way back and the thought of limiting wheel travel with a bolt on bag made me cringe. It has not been an issue with the performance of this vehicle.
Yes, I can feel a tiny bit stiffer ride empty with 5-10 psi in the bags. Not bad, but there.
Here are some pictures of the Cadillac air suspension compressor I got from P-N-P for ten dollars and the manifold I fabbed and put together. The small compressors that they have will air your tires up, but it will take a long time and will cause premature death to the compressor. I used to air my wheeler tires up with the ARB compressor when I would come off the trail. It would take me at least an hour to air my 33 x 12.50 BFG MT’s from 12 psi to 25 psi. in addition, I wore the compressor out in about a year and a half. I now have a Power Tank set-up on the wheeler and I put it in the Ram when I am not towing the wheeler. The PT will allow me to air up my 35 x 12.50 MT/R's from 10 psi to 29 psi 15-20 times on a full tank. With the PT, I can also run air tools on the trail.
