air dog 150/ fuel gauge problems
Old 02-18-2010, 12:42 AM
carte89's Avatar
Since I installed my pump my fuel gauge has been off. Has anyone had this before? Is there a way to calibrate it. Thanks
Old 02-19-2010, 11:25 AM
carte89's Avatar
Anyone have an idea I could use the help
Old 02-19-2010, 12:22 PM
cbrahs's Avatar
did you pull the canister and run the lines thru the can? if so, you have the canister turned and the float is hitting the side of the tank and not allowing it to go thru full travel
Old 02-19-2010, 12:25 PM
tesla440's Avatar
What are you trying to calibrate?? The fuel pump or guage. If it on the pump, I would talk with airdog to see if they can either send you an adjustable pressure regulator like on the 165 II pumps or a different spring set.
Just as an FYI, I have my pressure adjustment screw turned all the way so that the adjustment screw is flush with the lock nut & I'm at 22psi.
Old 02-19-2010, 02:20 PM
carte89's Avatar
Thanks for the replys. I pulled The canister out to catch the shavings from falling in the tank. Then put it all back together and have the issue
dodge350c
11-06-2013 04:18 PM
ghstrider87
07-28-2011 08:07 AM
trailinone
16
06-19-2009 04:28 PM
diggity dodge
05-03-2008 12:42 AM
heavyJ
10-25-2007 09:08 AM
Quick Reply: air dog 150/ fuel gauge problems
