Aftermarket turbo questions
Old 01-06-2007, 10:11 AM
Smokeman's Avatar
I've done lots of reading on this but still have some questions:
1. Which aftermarket turbos are truly bolt on, I mean work with existing supply and drain lines, jacobs exhaust brake, etc?
2. I tow about 22K gross combined weight, tow both flat ground and mountains, have an aftermarket exhaust and intake and may use the smarty to add some additional power while towing (30-60 hp). What turbo would suit my needs to help move air for EGT control while meeting the criteria in question #1?
Thanks!
Old 01-06-2007, 10:29 AM
BlueDually's Avatar
get an sps 62/14 (6280), its a towing turbo, bolts up to the stock elbow/jake
Old 01-06-2007, 10:41 AM
973604x4's Avatar
ditto!!! i have one.
There seems to be some confusion as to if you need a different downpipe or not...but you don't. it will bolt up to the stock manifold and downpipe.
Old 01-06-2007, 10:54 AM
robert97dodge's Avatar
How much do these turbos usually cost?
Old 01-06-2007, 10:56 AM
973604x4's Avatar
there was a used one in the classifieds a couple of day ago...it was brand new in the box for $1600. Mine was $1800 i believe.
There are cheaper turbos out there, but theres a reason why. You get what you pay for!
Old 01-06-2007, 11:02 AM
jlibert's Avatar
heres my Silver Bullet with my pac brake. Jake will fit to, but you have to oblong the mounting holes and rotate the plunger/vaccum assembly. II can tell you how..........
Old 01-06-2007, 09:51 PM
Smokeman's Avatar
Thanks for the info guys!
Old 01-06-2007, 10:38 PM
dodgezilla04's Avatar
II SPS 62/14. cools fantastic when towing, i dont see over 1200*. supports the quad race and smarty over 500hp without getting too hot too fast. bolt on. no mods required.
Old 01-06-2007, 10:42 PM
White97GTVert's Avatar
The question I have is this. On the websites it always says you need an HX-40 downpipe if you have an auto? why is this?
Old 01-06-2007, 10:50 PM
Smokeman's Avatar
Yeah I saw that too....
Old 01-06-2007, 11:05 PM
morkable's Avatar
Smokeman, I paid around 2500 installed at NADP for mine. I love it, it is a great turbo for everyday use
Kevin
Old 01-07-2007, 07:03 AM
Smokeman's Avatar
Kevin
Hey thats good to know...I wonder if my club NADP card will get me a discount on that... So it bolted right up to your pacbrake without issues?
Old 01-07-2007, 07:15 AM
morkable's Avatar
yes and yes. Tell Craig or fester that I sent you,, Kevin from GP. You will love that turbo
Kevin
Old 01-07-2007, 03:30 PM
973604x4's Avatar
I saw it too...it worried me too.
Luken's SPS 66 is on the stock manifold and downpipe.....my SPS 6280 is on my stock down pipe, ATS manifold.
Don't ask me why
The best me and my DTT builder (also II distributor) can figure is that pre 04.5 trucks need the HX40 downpipe....since 03-04 trucks had smaller turbos maybe
Old 01-07-2007, 04:18 PM
bigwheels94's Avatar
Will that turbo spool properly with just a Quad XZT?
Quick Reply: Aftermarket turbo questions
