Afe stage 2
Old 06-07-2005, 11:26 PM
Lrdchaos's Avatar
Afe stage 2
I bought the stage 2 today, but accidently got the 5 gauge filter insted of the proguard 7....does this filter work better than the kn replacement that I had in the truck before? Do you recommend the prefilter?
Old 06-08-2005, 07:57 AM
lsgibb's Avatar
I don't have the progaurd 7 on mine either, I did put the prefilter on just to help keep the big stuff and water off of the filter. So far it has worked perfectly. When installing I had to trim the box in order to make it fit though. I had to trim around the AC line and the shock tower with a dremel.
Old 06-08-2005, 08:50 AM
Big Deezul's Avatar
how can you tell which filter you got? Sorry for the newb question
Old 06-08-2005, 09:30 AM
WildBill's Avatar
the PG7 airbox has a part # that starts 75-, and a gold filter
Old 06-08-2005, 02:44 PM
kipo's Avatar
Isgibb what is a pre filter? is that only offered with the stage II? if not where can i get it? i have the stage I and it's already pretty dirty. did they ever put out any cfm or hp numbers for the stage II. did you see any egt decrease?
thanks.
Old 06-08-2005, 03:24 PM
lsgibb's Avatar
thanks.
A pre filter is just a water resistant sleeve that fits over your filter to help keep water and large dust particles off of your filter. I use one to help keep water off the filter and also to help keep the filter clean so I don't have to clean it as often. click on this link and scroll down to the bottom there is a picture of the prefilters from AFE AFE stage 2
I always get mine from Outerwears.com which is who makes the prefilters for everybody else and they sell them direct for a lot cheaper. I believe AFE charges $41 for the prefilter whereas I got the same thing from Outerwears shipped for $28. Just call them and give them the AFE prefilter part# and they will quote you a price. The only difference is it will say Outerwears on it instead of AFE.
As far as the differences between Stage 1 and Stage 2, my understanding is they both flow the same, the only difference is the Stage 2 is enclosed in a box on 3 sides and the top which helps keep the turbo quieter. I went with the stage 2 to help with the turbo noise and also to help keep **** off the filter when I'm playing in the mud. I went out the other day playing in the mud and when I was done I had mud all over in the engine compartment but there wasn't anything on my filter just all over the box protecting it.
Old 06-08-2005, 03:27 PM
lsgibb's Avatar
The PG7 is gold the non PG7 is blue.
Old 06-08-2005, 04:11 PM
Big Deezul's Avatar
mine is blue...what is the main difference in the 2 filters?
Old 06-09-2005, 11:09 AM
kipo's Avatar
the pro guard 7 is a more/multi layered filter supposed to give you better filtration. thanks for the reply guys i'm gonna get a pre filter.
3500eh
07-29-2008 04:53 PM
TORQUE BEAST
06-08-2008 07:53 PM
goodeyesniper75
08-29-2007 11:54 AM
052500#1
13
01-06-2006 03:27 PM
Quick Reply: Afe stage 2
