75/140 severe gear
Old Feb 9, 2007 | 10:21 PM
06dually's Avatar
75/140 severe gear
Would ther be any problems with running 75/140 in the diff's. I am thinking of using Amsoil 75/140 but book says to use 75/90 I think.
Old Feb 9, 2007 | 10:32 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
probably too thick for the cold enviroment you live in.
Old Feb 9, 2007 | 11:00 PM
Vinceg99's Avatar
I thought there was something about the 75/140 with towing a lot? I would be curious to know as well since im about to pick up a PML rear diff cover and well obviously change my fluid..
Old Feb 9, 2007 | 11:36 PM
Strjock81's Avatar
I am running the 75w-140 in N. Illinois, and it has been below zero every night for 2 wks. I am also running it in the final drives and front axles on MFWD tractors as well.
I have a couple partial bottles on the shelf where there is no heat--and I was curious as to how thick it was in this weather. It shakes in the bottle, and pours well, so it is thin enough--Not much thicker than Delo 15w-40 was. I have been very pleased with the oil--The temp reduction in the diff while towing was unbelievable--with 75w-90 Valvoline syn in the diff it would be too hot to lay my hand on for more than a few seconds--with the Amsoil I can leave it on there all day, it is warm, but definitely not hot.
Old Feb 9, 2007 | 11:38 PM
Vinceg99's Avatar
Is the Amsoil Synthetic?
Old Feb 9, 2007 | 11:44 PM
Its All Good's Avatar
I believe it is.
Old Feb 10, 2007 | 12:32 AM
Nate-03 D's Avatar
Originally Posted by Its All Good
I believe it is.
Yes, your right the fluid is synthetic. Just about every AMSOIL oil is synthetic.
I don't run the 75/140 but I do run the 75/90 and it has done me well so far.
Old Feb 10, 2007 | 06:29 AM
Hunter11's Avatar
I run Royal purple 75w90 in the front and 85w140 in the rear. Very good results over the last 5 years.
Old Feb 10, 2007 | 06:43 AM
Almond Pale Ale's Avatar
Amsoil has a 75W-110 Severe Duty synthetic now, would be a nice compromise for those that don't tow much but want better protection than a 75W-90.
Old Feb 10, 2007 | 09:47 AM
C Schomer's Avatar
I used RP 85w140 in Co. and it was great in spite of all the naysayers. My test reports were the best of all the lubes I tried. What wt. you use depends on how you use your truck. If I used the truck hard at all I'd use a minimum of 75w140 unless I lived at Minot or equally cold place. I just haven't seen what I'd call adequate protection from 75w90 in these trucks. Craig
Old Feb 10, 2007 | 11:54 AM
BlueDually's Avatar
Ive got redline 75-140 in both front and back axles, it gets to -35 here, and the diffs have not blown apart yet
75-90 and 75 140 have close to the same poor points in cold weather, from what ive read
Old Feb 10, 2007 | 12:34 PM
XLR8R's Avatar
I use RedLine 75W-140 in the 11.5" AAM
Old Feb 10, 2007 | 01:16 PM
Vinceg99's Avatar
Well looks like ill run the 75-140 then.
Also im seeing everyone post either Amsoil, Redline, or Royal Purple what about Valvoline synthetic 75-140?
Old Feb 10, 2007 | 01:26 PM
Nate-03 D's Avatar
So my question here is for everyone running the 140 over the 90. What's the huge difference between the two, viscocity breakdown? Is their better protection in the 140 fluid?
Old Feb 10, 2007 | 01:51 PM
Arkapigdiesel's Avatar
Difference between a 140 weight and 90 weight gear oil is film strength and a thicker barrier of fluid so to speak.
You might lose a little MPG with a 140 gear oil, but it would be so minimal that it couldn't be calculated. The extra protection of a 75W-140 is more than worth it IMO.
