53 Block????
Old Nov 18, 2006 | 10:57 PM
scottmn1's Avatar
53 Block????
Could someone fill me in on this Inferior 53 block I have ran across on a couple of posts. What years were these out there? What is inferior about them? How can you tell if you have one?
Old Nov 18, 2006 | 11:02 PM
schaef_12's Avatar
The Later 98-2001 24v ctd were the only ones that may have the 53 block. If you do a search on it you will find alot of good info. The 53 block was cast with thiner cylinder walls and they tend to crack, but many people who have the 53 block have modified their motors and have had no trouble.
Old Nov 18, 2006 | 11:04 PM
scottsjeeprolet's Avatar
Here is everything you need to know about this subject. Although there are thousands of them runnin around without a problem, we seem to only hear of the bad ones.
http://www.stamey.info/Truck/Cummins...NewInformation
there is another site as well but i cannot find it right now.
Old Nov 18, 2006 | 11:13 PM
scottmn1's Avatar
Thanks for the quick response with the links guys. I was unable to find anything when I did the search prior to posting this thread. I guess from the info you provided I don't need to worry about it then since mine is a 93 model. Are there any problems that are specific to the 93 model engines that I should worry about other than the KDP that I have already taken care of?
Old Nov 19, 2006 | 08:12 AM
CIN'S DODGE's Avatar
Mrs. missin on a mission & keeper of the can
Mind you 53 blocks were also on the 98 12V not just the 24V.
Bubspc
Jul 27, 2007 10:32 PM
24Vford
Jan 2, 2007 11:14 AM
plow
Dec 28, 2005 02:42 PM
1320
May 17, 2003 03:28 PM
