4Ks without hd springs?
Old Jul 19, 2006 | 01:49 PM
Teddy Bear's Avatar
What are the dangers of running the 4kgsk without hd valve springs?
Old Jul 19, 2006 | 02:14 PM
rharveysr's Avatar
Floating valves meeting up with tops of pistons that is if you spin the motor up that high.
Rick
Old Jul 19, 2006 | 03:50 PM
apwatson50's Avatar
Does anybody have the cummins part number for those?
Thanks, Aaron
Old Jul 19, 2006 | 04:26 PM
TxDiesel007's Avatar
None really if u watch ur tach
I run the 4K kit without them at the moment, and without keepers and retainers, Yeah i know someone me. Anyways So long as you do not rev the engine excessively above 3200-3500 RPMS ull be ok. Remember its at about 3700 or so that valve float starts to occur, so keep it below that and ull be fine..
Anyways by then, as another safety measure for me, my tach is at 3300 or so and my pyro is in the red with my fuel, so for me savin my headgasket, pistons, and valves all runs in one But im "minorly" overfueled
Rick
Old Jul 19, 2006 | 07:54 PM
Teddy Bear's Avatar
Thanks for the replies. Can you even get 4Krpms out of a 180 pump with stock dvs?
Old Jul 20, 2006 | 12:14 AM
12valve's Avatar
doubt it!!!
and, We are running 4k gsk in our 95 dodge 215 std now too, without HD valve springs, i just bought a set of only HD springs from a guy for 108 bucks,
PM me if ya wanna see if he got another set for ya!
and i know New Era Diesel sells them for 150 bucks!
the HD springs are a loooot taller and stiffer and thicker!
Old Jul 20, 2006 | 02:23 AM
bgilbert's Avatar
3916691 http://www.haisleymachine.com/PERFOR...20PRODUCTS.htm
Old Jul 20, 2006 | 11:20 AM
vssman's Avatar
With an Auto tranny - 4GSK is fine without valve springs. You'd have to purposely push it to get it to rev up there (like in neutral, etc...)
Old Jul 20, 2006 | 12:34 PM
Forrest Nearing's Avatar
no danger... I had them in my 215 pump... just don't go over 3400ish, and you'll be fine
Old Jul 21, 2006 | 02:58 AM
Teddy Bear's Avatar
Got them installed tonight. Throttle isnt horribly touchy like i expected. So far ive had it to 3500 and it runs pretty clean. Im afraid to go over 3500rpm but i still have some pedal left so im pretty sure i could get at least about 3800 or so out of it if i had the HD valve springs.
Old Jul 23, 2006 | 07:44 PM
joefarmer's Avatar
Yes. Mine will do 4450+. I don't have the stomach to rev it higher.
brandon.
Old Jul 23, 2006 | 11:34 PM
ratsun's Avatar
brandon.
_______________________
Hey Brandon what are you using for a tach? My stocker only goes 4k
Still lovin that trans? How high does it shift durring a WOT run?
Old Jul 24, 2006 | 12:22 AM
joefarmer's Avatar
The stock tach will run higher if you pull the pin out. I like the trans, but I'm having tuning issues. Its shifting at WOT right as the power falls off around 3800. The problem is that light throttle street driving causes it to go 1-2-3-OD within the first 30 mph. I can't tune the TV cable any more, so I think I'll need a different VB?
brandon.
Old Jul 24, 2006 | 12:34 AM
ratsun's Avatar
Yeah that was one of my concerns when I was talking to Bill and Steffan but they assured me it could be done so.......? I plan on doing the trans after the kids are back in school since its too busy with them out. I will pm you in a month or so to see how you have made out. Good luck with it
JaimeG
Mar 26, 2009 06:58 AM
Tingram
Oct 15, 2008 10:18 PM
53 willys
23
May 19, 2008 06:14 PM
95turbo4wd
Dec 12, 2007 05:59 PM
bigred496
Oct 22, 2004 07:16 PM
